car shuts down at 115, with a performance chip
Old Oct 28, 2001 | 11:03 AM
Dans91's Avatar
Car: 91 RS
Maybe anyone could help me with this little question, I went and finally bought a performance chip for my 91 RS by hypertech, and i thought that was supposed to cancel out my governor but maybe i am wrong. Well i just wanted to see if anyone knew the scematics on how to bypass the governor.
thanks for any help!!
Old Oct 28, 2001 | 11:16 AM
firbird's Avatar
some reasone i dont belive they cut it out but i may be wrong but if you wanna get rid of it just go under the tec articles and they have one on getting rid of the speed limiter on our cars
Old Oct 28, 2001 | 11:30 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I was told by the rep that it would be extra to have the speed limiter removed. Like firbird said though there is a way to do it yourself.
90 IROC
SuperRamed 406
Trickflow 23* heads
Old Oct 28, 2001 | 11:31 AM
Vader's Avatar
Dan,
Yet another reason to shop for aftermarket PROMs somewhere other than HyperTech. Because of liability, they maintain the speed limiter programming. If you had purchased the PROM for a car with the 16" wheels, you would not have had a speed limiter (fuel cutoff) programmed at 118 MPH. The fuel cutoff for cars with the RPO options PW7 / QDZ, the fuel cutoff would be programmed at 254 MPH (the maximum setting of the cutoff parameter).
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 28, 2001 | 11:46 AM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
I think I have the same chip as you (in my 91 Formula). Hypertech says that they leave the cutoff speed the same as stock, which is supposed to be just below the speed rating of your stock tires (118 for the "R" tires, I think).
I tried it out, just for grins, anyway - kind of a bummer to have the computer cut off your fuel like that, huh? Oh, well... I don't need to drive around over 110 mph anyway (I don't exactly have a 12-13 second car).
My guess is you need to burn your own chip (or have somebody burn you a custom chip) to change this.
Joel Geerling
Red 91 Formula, 305 TBI
Edelbrock 14x3 open element
TBI 1/2" spacer
Hypertech street chip
Crank/Alt Pulleys Exhaust is next!
Old Oct 28, 2001 | 12:26 PM
DM91RS's Avatar
Car: 91 RS
Ok guys, this is just another Hypercrap ripoff and another reason for burning your own chips. I just returned from a morning drive which was limited to 5200 rpm at 130 plus. 4th gear.
This cool air today makes for great running.
91 RS 5.0 TBI....LT4 cam....Edelbrock headers....3"Dynomax exhaust....5spd.... 3.08.....Ultimate tbi....afpr...ZR 255-50's...Koni's
[This message has been edited by DM91RS (edited October 28, 2001).]
Old Oct 28, 2001 | 12:47 PM
CODY BEHNKE's Avatar
It's Hypertech not Hypercrap.
Hypertech chips come with the top speed limiter at stock mph, it's more $$ to get it removed. It doesn't matter what tire size you have either. Hell my Formula came with ZR50 Goodyears on it but stock limiter was still around 110mph. Another good tip is to order factory direct so you can order by chip/ecu # too.
Old Oct 28, 2001 | 11:00 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Nope, its Hypercrap.
I made a post on the TBI board a few months ago when I found out their chips dont remove the speed limiter. You need a custom chip to do that.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 28, 2001 | 11:10 PM
Vader's Avatar
Cody,
You're right on both counts. The paperweight on my desk doesn't read "Hypercrap". I think it is "HyperScrap". I actually do better with the upgraded factory GM PROM than I did with the ThermoMaster PROM.
And the tire size doesn't matter, but the speed rating of the tires as delivered from the factory does matter. If the car was delivered with "Z" rated tires of any size from the factory, the fuel cutoff parameter was entered as "254". It's just most common to have the "Z" tires delivered as the 245/50-16 size. If your Formula 350 TPI was delivered from the FACTORY (not the dealer) with Gatorbacks, they screwed up. It happens.
Later,
Vader
Old Oct 29, 2001 | 02:22 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
<font face="Verdana, Arial" size="2">Originally posted by CODY BEHNKE:
</font>
Ummmm.... no...., I'm pretty sure it is hypercrap... or Hyperjunk or Hyperpoop or something like that. Definately not Hypertech....
This just gets more laughable by the second!!...lol
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Oct 29, 2001 | 12:53 PM
I admit hyper_ _ _ _ whatever is funny but I have tried JET,Performance Resource,Fastchip,Superchip with no avail Hypertech worked good in my91 RS auto and in my car now. My car is a TBI Formula and it came with the Gatorbacks and the 110 speed limiter. All WS6 and IROC's with 16's came with Gatorbacks from the factory but the TBI cars came with the 110mph limiter.
1991 Formula WS6
305 LO3 TBI 5-Speed 49,000 miles Dynomax Cat-Back,Hypertech Chip,etc..
Old Oct 29, 2001 | 02:08 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Just put that switch in that disables disconnects the vss from the computer. just flick it when you are on a really long straight road. I may set a check code when the vss is disabled though. I thought I had read a tech article on it.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
The_Phoenix
Feb 4, 2016 07:10 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
Exxon Limited
Aug 9, 2015 08:13 PM
Fronzizzle
Aug 9, 2015 01:15 PM
