dropping motor in with headers on
Old Sep 19, 2005 | 04:55 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Axle/Gears: 9 bolt 3.91
I wanted to know if I could drop my motor in with my hedman shorties attached. I was going to go with long tubes, but I have a t-5. thanks
Old Sep 19, 2005 | 05:51 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Shorties can get installed after the engine gets dropped in. I would personally install them after, more space around the engine to move around with, if need be.
Old Sep 19, 2005 | 06:04 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Re: dropping motor in with headers on
There are problems with that combo? I have LTs and plan on getting a T5 very soon.
Old Sep 19, 2005 | 06:14 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
With my hedman long tubes the only way to get them in/out is to pull the motor.
Old Sep 19, 2005 | 07:53 PM
BOTTLEDZ28's Avatar
Transmission: A4
I put my engine in all the time with my SLP headers already on the engine.I do this becuz I find it easier to properly torque down all the header bolts. Yes, I knowit can be done after but I have not had any trouble getting the engine in with them on. I also have no A/C either so that helps a bit. I put my engine in once with header , clutch and bellhousing already on and I will say this.... major PITA. Iwont do that again.
Old Sep 19, 2005 | 09:07 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
My hedman shorties hit when attached to the motor. Its easiest to put them on when the motors 1-2" above the motor mounts.
Car: 86 T/A
Engine: HSR 355
Mine slide right in front underneath.
Old Sep 20, 2005 | 03:54 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
i'm going to put the headers in just before i drop the motor all the way down, I was going to bolt the bell housing on too, becasue that one bolt on the d/s is a pita to get to.
Old Jul 5, 2006 | 09:45 PM
drshirk's Avatar
Car: 91 Camaro RS Convertible
speaking of that "one bolt on the drivers side" !!!!!!!!!! I am pulling my 700r4 out of my 91 camaro. I have never done this before so it is all new to me. I have everything that needs to be disconnected cables, lines, crossmember, mount etc. I just cant seem to get to that one d*mn bolt. I used two 10" extensions. I get the socket on the bolt but then there is no room to turn the ratchet. I tried using a wobble socket but that just seemed to make it harder. To me it was harder that is. I am going to buy another extension and see if I can get to it any better to turn the ratchet. If anyone has any suggestions please let me know!!!
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
E Rod
Aug 28, 2015 05:17 AM
Elliswon
Aug 10, 2015 12:33 PM
