best choice 4 engine rings
Old Oct 31, 2001 | 01:58 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
What is the best ring for street use? I don't want a set that is going to wear out in 30k miles or wear the cylinder walls out early either. Yet needs to be able to run in a 6500 redline 400hp 350.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Oct 31, 2001 | 02:06 PM
Damon's Avatar
Standard set of moly-faced cast iron rings will do just fine. Pick the right pistons for your application and the exact ring choice will become obvious at that point.
Old Oct 31, 2001 | 04:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, what he said. 400 HP at 6500 RPM in a 350 is a walk in the park for the rings, nothing special required there. The standard Speed Pro moly rings are fine, but if you want the best, get their plasma moly ones.
Bore prep is more important than high-dollar or exotic rings. Simple things, like making sure the honing grit is all washed out and not chewing the rings up during handling & installation, are what makes the difference.
ICON Motorsports
Old Oct 31, 2001 | 05:26 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
pretty much the only rings i preferr to use are total seal gapless.
Old Oct 31, 2001 | 05:48 PM
ede's Avatar
ede
moly coated iron rings are fine for most applications including yours. like rb said make sure the bore is clean and the correct grit stones used for your rings. gapless rings are pointless for street and a lot of preformance applications.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 31, 2001 | 08:42 PM
GOLD85's Avatar
i choose to run speed pro moly filld file fit rings
when the green flag drops the bull$hit stops
pulled the 350 to make way for the 406 wich is in the machine shop. got a comp 282S bump stick with 1.6 rockers. looking at differnt heads right now.Perfomer RPM and holley 650 DP, headers and 3 inch exhust. 3000 stall converter and a built 700r4. shotin for mid 12s next summer
Old Nov 1, 2001 | 12:39 AM
SoCo80p's Avatar
i would just spend the extra 40$ and get the speed pro plasma moly rings, there at a good price and VERY durable,
Old Nov 1, 2001 | 06:36 AM
Thanks guys.
hectre13
Dec 11, 2023 08:14 AM
camaro71633
Sep 1, 2015 10:24 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
