Make it stop :(
Car: 1987 Z28
Engine: Tree Fiddy (modded)
Make it stop :(
So heres my issue of the week
If I accelerate to quickly theres a big CLUNK! in the tranny area, it seems. And if I do a tail whip around a corner it goes from clunk to a grinding on the transmission well. Thats what it feels like at least.
What the hell can this be
its really annoying
its really annoying
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Trany mount, almost 100% sure. These things break way too easily on these cars. Try putting a jack under the tailshaft of the trans, you will probably find it will lift right off of the crossmember.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Grab a new mount, A poly mount is a bit stronger and prefered. Im not sure about pricing in your area but you should be able to pickk up a poly mount for under $30.
Car: Pair of 92 Z28s
nope...u get a poly urethane transmission mount. Its an easy fix blew mine apart within 2 weeks of having the car...fun stuff. Oh ya and my gfs RS needs one also
But ya calm down with ur new whip lol.
Car: 1987 Z28
hey thanks alot man
I just did a search of "transmission mount" and seen that seems to be the problem people are having when they have those symptoms, thanks alot, it was getting annoying with the big CLUNK.
you kick ***
I just did a search of "transmission mount" and seen that seems to be the problem people are having when they have those symptoms, thanks alot, it was getting annoying with the big CLUNK.you kick ***
Car: 1987 Z28
thanks guys, without these boards I would be lost
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
I have broke 3 of these friggen mounts this summer
The second time it broke i made up a chain that goes through the mount and around the x-member to try and save my drivetrain and floor.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Almost with these cars!
If your running a stock or semi-stock car it wont be as bad.
With my semi-healthy 350, TH-350 trans w/shift kit and 4:11 gears in the back im a little hard on stuff.
I cant imagine how bad this things going to be with a blown 383 twisting that driveline.
Edit: yes, poly urethane mounts except for the first time it was the original rubber mount from 84!
Car: 1987 Z28
hahah well then i guess for the rest of this week i gotta take it easy
i get paid friday and my parents are out of town so i cant borrow money
haha Thanks again for tellling me what it was
haha Thanks again for tellling me what it wasSupreme Member
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Take it real easy if you plan on driving it, let that tranny jump up too many times and youll have alot bigger bill.
just FYI, notice the torque arm on the back of your trans that runs to the diff? If your trans goes up that will twist your rear end too, really putting the driveline out of wack.
i managed to drive on my broken trans mount for a good 2 weeks before doing something...it got worse and i was not gonna wait any longer in the period i was hard a few times but it was mainly like too much gas from a stop it sounded terible. Till i posted on TGO i was hopeless...
I was lucky...i thought at the time my tranny was done for.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
If you wanted to go real ghetto for the week you could tie it down with a chain or rope, just incase that foot gets a bit too heavy it wont bash apart everything.
Car: 82 Camaro
Axle/Gears: 3.08
When I pulled my V6, i'd had a progressively worse *CLUNK!*. The tranny mount itself was ok, but the bushings between the 2 parts of the crossmember were gone on the driver's side.
