Thump noise from passenger rear wheel from dead stop?
Old Oct 13, 2005 | 03:59 PM
JungleMan's Avatar
Car: 91 Firebird, white
Engine: L03 :(
Axle/Gears: 4th gen, 3.23
Here's my problem...ok...so from a dead stop (or very slow roll), if i give it a lot of gas, the passenger rear wheel makes this "thump" noise, usually twice, but if I'm easy on it it doesn't do it. It's even happened when going from 1->2, so long as I'm really giving it some gas. However it does NOT happen in Reverse.
I jacked up the rear of the car, and it doesn't do it when i get on the gas, but the passenger rear wheel thumps when i press the BRAKES...
Any clues?
Old Oct 13, 2005 | 05:57 PM
sellmanb's Avatar
Car: '86 Berlinetta
1) Are you sure it's not just wheel hop?
2) make sure your spacers and wheels are on tight still.
Old Oct 13, 2005 | 06:30 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
definately make sure your not falling apart
Old Oct 13, 2005 | 09:49 PM
JungleMan's Avatar
Engine: L03 :(
Well I played with it a bit tonight and it seems that it's my U-joint-- really nothing to do with the passenger wheel, I guess I somehow thought the noise was coming from there...
Anyhow, the U-joint has a bit of play in it. Not very much at all...just a bit.
Can someone point me in the right direction on where to get a new one (what kind to get) and any info on how to replace it? Thanks
Also I will be driving the car about 150 miles tomorrow, will it still be safe and everything? The car feels fine once I'm up and going, and only thumps when I hammer it from a stop.
Old Oct 13, 2005 | 10:44 PM
sellmanb's Avatar
Car: '86 Berlinetta
Good excuse to upgrade to an aluminum driveshaft from a 4th gen. You will be amazed how much smoother your ride is with one.
If you go to the parts store and ask for a u-joint from a _____ camaro/firebird w/ the ______ transmission and _____ sized engine.
If you have 1LE, then dont bother w/ the 4th gen driveshaft, yours is already aluminum. If not, definetly look at those driveshafts. Best 150 dollars you'll spend on your car (aside from SFC's IMPO)
Old Oct 13, 2005 | 10:51 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
If your running an all stock setup grab a greasable one, you wont need the added strength of a solid body ujoint. Keep it lubed up and it should last quite a while.
Old Oct 13, 2005 | 11:02 PM
JungleMan's Avatar
Engine: L03 :(
SFCs are also something I want to do eventually...
Does the aluminum driveshaft improve acceleration or handling at all? Don't see how it would improve handling but acceleration, definitely, less unsprung weight...
I might have to keep my eyes peeled for one...
Old Oct 13, 2005 | 11:07 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Tranny mount brotha!
Put a jack under your tranny and lightly lift it. If it does not give you any resistance and pushes up freely you will see your mount cracked in half.
If not, than do check the preassure in your tires, but I highly doubt it.
Old Oct 13, 2005 | 11:55 PM
sellmanb's Avatar
Car: '86 Berlinetta
the aluminum driveshaft is lighter, therefore less rotating mass, therefore more power to the wheels. But mostly, they're made better in the 4th gens, and a lot of the "high speed vibrations/rattles" , etc that you might not even notice now, will probably go away. For some reason our stock driveshafts are just horrible.
Your u-joints will have to be pretty bad for them to clunk into gear, and when you snap on it from a stop. Not horrible, but a little play (like less than 1/3 an inch either way) isnt unusual.
Continue to look at other options. Like stated above, check your tranny mount with the described method. If everything else checks out OK, time for a driveshaft
Check out www.camaroz28.com 's classifieds for good deals on that
Old Oct 14, 2005 | 09:51 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Have you checked to make sure your spare and jack are secure?
Old Oct 14, 2005 | 10:06 AM
JungleMan's Avatar
Engine: L03 :(
The spare and jack aren't even in my car right now, but I'm sure the noise is coming from the actual car.
Hmm I will try the trans mount... are these "transmission mounts" on either side of the crossmember? Sorry I'm not a real transmission person I just need to know what to look for when I test it...
The U-joints do have a very small amount of play but this may be normal as you said, so I will test out the transmission mounts, and if that's not it then a new u-joint (or maybe driveshaft) for me
Old Oct 14, 2005 | 03:04 PM
JungleMan's Avatar
Engine: L03 :(
Well on the way home from school today I bought a trans mount, just in case. Didn't even bother buying a U-joint.
Jacked up the trans as one member suggested, and sure enough, that transmission went right up...replaced that transmission mount with a brand new one and all is well...in fact it rides even smoother than it did before!
Thanks, now I can be amateurish and floor it from a dead stop without making funny noises!
I still think one of these days I might look into that alu driveshaft though, not now though, more important stuff to buy like Sportlines and SFCs.
Old Oct 14, 2005 | 03:35 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Yep, just did my tranny mount last night, wasnt too bad. 6 bucks at autozone, so we will see how long it holds up. Eventually ill order the poly.
Old Oct 14, 2005 | 03:51 PM
JungleMan's Avatar
Engine: L03 :(
I also got mine at AutoZone for $6. I wanted the poly too, but I really wanted it fixed tonight as I'm doing a good bit of driving this evening.
Worse comes to worse and the mount breaks, all I have to do is buy the poly, it didn't take me very long to replace the mount, so no biggie. But if the stock mount held up for 15 years then this one shouldn't do too bad!
Old Oct 14, 2005 | 04:12 PM
CrimsonDragon's Avatar
Car: 89 IROC - 85 Z28
Engine: 350 / 305
Transmission: 700R4 / T5
Axle/Gears: Stock
I went through 3 stock trans mounts before I went with a urethane one. Check out Spohns website for a quality replacement if your stock one breaks again.
Old Oct 14, 2005 | 10:58 PM
Old Oct 15, 2005 | 12:57 AM
JungleMan's Avatar
Engine: L03 :(
Don't see how quickly a stock one is going to break if the original one from late 1990 held up for 70K miles, but I guess we'll see
I drove the car tonight and noticed that it rode a lot better than it did before the trans mount broke! I guess the old one was a bit worn though not broken
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
hokis
Aug 9, 2015 03:57 PM
