proper name?
Old Oct 16, 2005 | 02:55 PM
84camaroZ's Avatar
Car: 1984 Camaro Z28
Engine: LG4
Transmission: th-700
proper name?
there is no where to put this on my new carb. it came out of the back of my quad. its the power brake hose or something right?
Old Oct 16, 2005 | 03:26 PM
gotmilf's Avatar
Car: 84 Z28, Silverado 2500HD
Engine: 5.0
Transmission: t-5
That is a vacuum hose to the power brake booster. It is a must keep.
Old Oct 16, 2005 | 03:59 PM
84camaroZ's Avatar
Engine: LG4
i cant figure out where it goes on my new carb though?
Old Oct 16, 2005 | 04:01 PM
ede's Avatar
ede
look for a port on the intake, or a plug you can remove and put a barb fitting in
Old Oct 17, 2005 | 09:40 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Brakes are a good thing. Definately keep the vacuum to the booster.
Jim.
Old Oct 17, 2005 | 10:06 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You have to fit it to a port on the intake manifold, or either Tee off of the pvc port on the carb.
Old Oct 18, 2005 | 09:40 AM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
what carb? The edelbrock 1400 series has a port in the back of the carb you need a 90* barb i thinkn it's a 1/4" thread with a 3/8" barb. Call your carb mfgr or the place you bought it or take it to a mechanic and ask. If for some reason your carb doesnt have one, your aftermarket manifold (hopefully you got on eof those too) will have a spot right behind the carb.
Edit: Or, summit has electric pumps to use for your power brakes if you are running a big cam, it would work for your reason too.
Old Oct 18, 2005 | 08:04 PM
84camaroZ's Avatar
Engine: LG4
there was another hose that came out of that spot on my stock manifold. it was very small. i know where you are talking about though.
Elephantismo
Feb 13, 2019 12:51 AM
FormulaEngland
Sep 30, 2015 01:50 PM
dusterbd
Sep 29, 2015 08:40 AM
wstephan96
Sep 25, 2015 04:28 PM
