cam and intake?
Old Nov 18, 2001 | 05:41 PM
korbin's Avatar
cam and intake?
my car is basically a stock 305 TBI
and i am wanting a new CAM and intake manifold and maybe an edelbrock 600 cfm carb.... anyone have better recommendations? i just want to run maybe 13s in the quarter.....
Old Nov 18, 2001 | 06:41 PM
Joshua Leslie's Avatar
ur not gonna get it to run 13's with just a cam and intake combo.
You need about 300h/p to hit a high 13.
a 305 with cam/intake and ported heads will maybe get u into the 13's.
Old Nov 19, 2001 | 01:25 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
You will likely need a higher stall torque converter to dip into the 13s. It ain't easy with a 305.
Old Nov 19, 2001 | 08:51 AM
korbin's Avatar
ok so new cam, intake, raised fuel pressure, torque converter, and ported heads....anything else??? ANY SPECIFIC KINDS?
Old Nov 19, 2001 | 10:56 AM
edelbrock performer rpm, 750cfm carb, stock ported heads, 1800rpm stall, headman shorty headers with Y pipe.
Or you could just get a edelbrock tbi perforemer manifold and upgrade the injectors, if you are just keeping the 305, its not worth it to rip the fuel injection off.
Old Nov 19, 2001 | 11:43 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The best intake you can put on it right now would be a set of good headers. All the intake in the world won't do you a bit of good if whatever you can cram into the motor can't get back out.
The bottlenecks in that motor are, in order of importance: the exhaust, every single piece from the heads to the street; the cam; the heads; the air filter; and then after all that is opened up, the intake and TB. Spend your money wisely on the weakest link instead of slamming the romantic-looking highly visible bolt-on to the top of the motor that accomplishes nothing.
ICON Motorsports
Old Nov 19, 2001 | 12:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I should also add, before you need to waste money on the intake manifold "eye candy", you also need a decent rear gear. You have 2.73s now, the worst choice of all those avaliable in these cars from a performance point of view. That's not an engine mod per se, but is essential to get your money's worth out of whatever you do to the motor.
ICON Motorsports
Old Nov 20, 2001 | 01:18 AM
Engine: 305-4v
<font face="Verdana, Arial" size="2">Originally posted by RB83L69:
</font>
The one thing that saves you, if you have 2.73s and a 700r4, is that massive first gear at 3.06 to 1! In comparison to any other GM transmission (auto or standard) this turns your 2.73s into 3.23s!
Thus a roughly 2200 rpm torque converter ought to make that Camaro come off the line pretty well, compared to most other setups
beastin91rs
Oct 9, 2015 07:38 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
hayesaw0210
Aug 23, 2015 11:15 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
