How do i siphon gas out of my tank?
Old Nov 18, 2001 | 07:57 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have stuck a 10 ft piece of hose down the tank and its not even touching the gas. Whats going on? is there a trick to this. It feels like I'm hitting a spring or something.
Old Nov 18, 2001 | 08:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Welcome to GM's anti theft system. It's almost impossible to siphon gas from a GM tank now.
Old Nov 19, 2001 | 03:14 AM
Jza's Avatar
Jza
Wiggle it in and out while rotating it. You'll drive her nuts. I mean, you'll dip it in eventually. Helps if it's slightly curved (should already be curved to the left, right?).
If you get sick if doing that, you could go under the car and unhook the filter and stick the tube onto the fuel line, then run 12 volts to the pump (you can do that at the ALDL connector).
Old Nov 19, 2001 | 09:07 AM
SoCo80p's Avatar
just go to the parts store and get a tank siphon pump, there like 10$ and work great!
Old Nov 19, 2001 | 09:37 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
[QUOTE]Originally posted by Jza:
[B]Wiggle it in and out while rotating it. You'll drive her nuts. I mean, you'll dip it in eventually. Helps if it's slightly curved (should already be curved to the left, right?).
Nice visual.....
-Rich-
Old Nov 20, 2001 | 03:49 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well here's something that's kind of cool; GM's hung the fuel sending unit right in front of the filler neck opening! Yep, that's what you're hitting with the hose. I assume it was put there to wash down the fuel sending unit.
Are you replacing the electric fuel pump? If so, the thing might have enough "kick" to drain the tank for you. Unhook the fuel filter, and lead a hose from the feed line to a gas can. Put the key to "on" (so you can watch the gas gauge). Apply +12 to the fuel pump "test connector", which will energize the pump. Remove the +12 when your gas gauge shows empty. Oh- do this outside, and don't smoke, or drop any wrenches, or play with explosives near the gas. Okay?
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 20, 2001 | 06:19 PM
irocbsa's Avatar
Wait a minute, what are you saying??? Gasoline burns???
bsa
Old Nov 21, 2001 | 11:18 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Well There was half a tank and we couldnt get it out so me and my dad got under there and got it out. It was SO easy getting it out. Why does everybody complain about bending the neck? We rolled it forward while gently pulling out and wham dropped right out. Very Easy Thanks for the suggs guys
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Bohemian
Aug 15, 2017 05:11 PM
amcnellis
Sep 16, 2015 04:16 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
