Car stops when put in drive at idle?
Old Nov 23, 2001 | 09:09 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
I just got done with my engine upgrades, and got most the bugs straightened out. As you may have seen from posts these last few days - I had some initial problems, but they are worked out now.
So, the only problem left is that the car does not want to run at idle while in drive or reverse. This especially is a problem when slowing down towards a stop sign or light etc.
The timing is set at 9°.
The upgrades done include pretty much everything in the sig.
What can I do to get this problem straight??
Thanks for any and all inputs!!
Ken
1986 IROC-Z Conv't
- White Gauges, 17x9.5 TT II rims w/275/40x17" F1s, 1.5" Jamex Lowering Springs, BMR stb, Lakewood APR, PST suspension parts, Edelbrock Trailing Arms, KYBs, Edelbrock RPM Cat-Back, Edelbrock JHC Headers, Catco, World Products Heads, CompCam, SLP runners, Ported Plenum, K&N, Airfoil +polished/billet dress-up stuff
ChevyKen's Cars
Administrator @ ChevyWorld.net
Old Nov 23, 2001 | 09:36 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I would check to make sure your TC lockup is working properly.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 23, 2001 | 10:23 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Axle/Gears: 3.23 and 3.27 posi
My '85 Z28 used to do this also. It turned out to be a bad Idle Air Control valve. Of course I'm assuming you have TPI.
Old Nov 23, 2001 | 10:38 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Mark A. Shields,
Well, I would like to think that the TC isn't the problem - especially since it was working perfectly fine until the mods and the only thing done to the trans is oil/filter.
So, I do think it is more related to the swap of heads/cam/headers/catback/runners/plenum ?
RSFreak,
Yes, I do have TPI - where is the Idle Air Control Valve located, and is there a way I can test it?
Thanks guys!
Ken
Old Nov 23, 2001 | 10:48 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ken, the TC lockup could be the problem, does the car shake or wier vibrations before it dies. If so then It is the TC lockup if not then it could be the IAC. Your supposed to be able to test the IAC's voltage (14.2) but as how to test it I'll leave it to a TPI guy.
SSC
Old Nov 23, 2001 | 10:59 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
I can't say I've noticed any vibration. If the TC is the problem, would it need to be replaced, or is it something that needs to be adjusted?
When the engine stops it is just winding down on the rpms until it just stops. I can prevent it from stopping by just keeping the foot lightly on the throttle though, if that makes a difference to wether or not the TC is the problem?
Thanks again,
Ken
Old Nov 24, 2001 | 08:14 AM
Jza's Avatar
Jza
IAC valve is in the side of the throttle body. Has a huge hex on it (11/16th if I remember right).
You can tell if it's the TC if it acts exactly like a manual car does when you brake to a stop and don't depress the clutch.
Old Nov 24, 2001 | 11:04 AM
Car: 99 Formula
Axle/Gears: 342
Or just get up to like 55mph, in OD. Slightly tap the breaks the rpms should jump up a couple hundred rpms.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86IROC112
Aug 17, 2015 02:00 PM
