Exhuast in car
Old Nov 23, 2001 | 10:36 PM
Buck268's Avatar
Exhuast in car
Does anybody else get the exhuast 'sucked' into thier car when driving around with windows down? I have stock exhuast system, downturned stock tips.
Old Nov 23, 2001 | 11:18 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Sounds like you might have an ex. leak somewhere....
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Nov 24, 2001 | 09:55 AM
Buck268's Avatar
I thought I saw some exhuast leaking out from my car (infront) a few weeks ago, in the morning...but I have been checking every now and then (when its cool out, of course), and I havent seen it again..
Old Nov 24, 2001 | 10:11 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Does the car make a "ticking" sound or is it any louder?
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old Nov 24, 2001 | 10:26 AM
Buck268's Avatar
Actually, it does make a kind of 'ticking' noise
Old Nov 24, 2001 | 12:02 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Time to jack it up and check it out.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited November 24, 2001).]
Old Nov 24, 2001 | 12:05 PM
Buck268's Avatar
How could I tell, for sure, if I have a leak?
Old Nov 24, 2001 | 01:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well, you could check to see if you smell exhaust inside the car with the windows down... that's a pretty good sign. Seems like you've already got that covered, so it's clearly established that you have an exhaust leak, time to find and fix it.
Start by tightening all the bolts under the hood. That would include all the bolts that hold the manifolds to the heads, and the Y-pipe to the manifolds. Then put the car up on jack stands and get up under it with the engine running, and listen for leaks.
ICON Motorsports
Old Nov 24, 2001 | 01:42 PM
Buck268's Avatar
ok
Old Jan 30, 2002 | 12:00 AM
89rs305tbi's Avatar
Ticking
What actually makes the ticking noise?
Old Jan 30, 2002 | 07:51 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
An exhaust leak close to the engine makes ticking noises. The pulses from individual cylinders, escaping through the leak, make the sound.
Old Jan 30, 2002 | 08:08 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If the ticking is around your feet, I would take a look at the Y-pipe.
Old Jan 30, 2002 | 09:10 AM
Hellraiser's Avatar
Re: Exhuast in car
I had a problem like that on one of my birds that continued even after all the exhaust leaks had been buttoned up. Turned out there was a sizeable rust hole in the passenger rear quarter under the spare tire.... whenever i drove it sucked the exhaust straight into the car. Maybe not your problem, but check anyways as its easily overlooked.
Old Jan 30, 2002 | 05:12 PM
Buck268's Avatar
LOL. Well, on a possibly related note, the carpet under my floor mats is ALWAYS wet. I mean, it could be like 80 w/ 0% humidity for like 2 weeks, and the carpet will be wet...and when it rains.... Now, this is bad, i know...but I could mayeb have a small rust hole. But first I gotta fix my floor jck, it blew an o-ring! (i think...)
Old Jan 30, 2002 | 06:17 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
Jack the car up high, preferably a lift. put a large, damp rag over your exhaust briefely. if you have an exhaust leak you'll defienately hear it screaming out of wherever the hole is. this works best with two people, one covering the exhaust at the back of the car and the other feeling around where the leak is coming from. do this while the engine is cold so u dont run the chance of getting burned, it will take a couple minutes for the gasses to get real hot. oh and dont hold the rag there too long, your engine wont like it.
Old Jan 30, 2002 | 06:20 PM
Buck268's Avatar
Yeah, I'd imagine it wouldnt. Um, I am thinking I should just go try 2 climb under my car one morning, whens its nice and cold out and look fer exhuast.
Old Jan 30, 2002 | 06:32 PM
TekViper's Avatar
Engine: 3.1L v6
thats a good idea. just have someone cover the exhaust temporarly for a few seconds. if your going to do it on the ground tho where some goggles and at least get a jack on one side. flashlight will help to spot holes too.
oh and double check that its in park, might even want to pull the ebrake too
Old Jan 30, 2002 | 07:31 PM
Buck268's Avatar
Naturally. Safety first!
Old Jan 31, 2002 | 04:44 PM
bzznczzn's Avatar
Check to make sure your hatch is closing properly. I had this problem. When i bought my car, the power pull down hatch was messed up, so the hatch wasn't sealing. Soon as you roll down a window, it sucks the fumes in through the hatch. Check this out and see if it's your problem. My car was so bad that you could see carbon buildup inside my hatch/trunk area.
Old Jan 31, 2002 | 08:48 PM
Buck268's Avatar
Wow. Thats an interesting idea. Maybe I should check this out...But might there be like wind noises (you know what I mean...right?) if your hatch isnt sealing good?
Old Jan 31, 2002 | 09:06 PM
bzznczzn's Avatar
To be honest with you, I never heard any sounds whatsoever. They could have been there and i never noticed, but I really never heard a thing. I'd definately check this out. Your hatch may not be fully closing or the weatherstriping might be bad. Mine wasn't locking down tight, because of my power hatch being bad. I ended up driliing two holes into the track when i had the hatch closing tightly and then perminantly set it in that position by simply sliding a couple bolts through the holes. Look at the lid where your hatch closes, if you see a black/brownish dirt builup, this could be your problem ( i think that only occurs if it has been happening for quite some time) I purchased my car with this problem and it was driving me nuts. Hope this helps you out
Old Feb 1, 2002 | 06:18 AM
Buck268's Avatar
It gives me a new idea. Thanks. Now I just gotta figure out a way (other that carbon build up) to test it...
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
