No Power!!
Old Nov 9, 2005 | 12:14 PM
CamaroSS_Black's Avatar
Car: 1986 Z28
Engine: L98 Block Vortec Heads Comp Xtreme
Transmission: Built 700R4
Axle/Gears: 10 bolt with Auburn 3.73 posi unit
No Power!!
i just finished putting my engine in and i wired my starter and battery and i got in the car and pull the light switch and nothing happened i have absolutly no power please help me out
Old Nov 10, 2005 | 06:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Make sure it's wired correctly. Make sure the battery has juice.
Old Nov 10, 2005 | 06:16 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Check any fusable links in the system...
Old Nov 10, 2005 | 09:11 PM
Car: 1986 Z28
yea i just bought an interstate battery just pulled the shrink wrap off of it and i bolted the battery and ignition wire to the large prong on the starter and nothing at all no lights or anything i dont know where it could go wrong the wire goes frm the battery to the starter and gets bolted on top of the ignition wire right? i also bolted the purple wire to the smaller prong
Old Nov 11, 2005 | 07:15 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
the purple wire with the smaller terminal IS the ignition wire. all that other stuff is basically power distribution. there are fusible links right near where all those wires hook up to the the starter along with the battery cable. you may have a problem there.
Old Nov 11, 2005 | 07:32 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Just wondering if you hooked up the ground wire, i have seen people go crazy with no power and it turned out they didnt hook the damn ground wire to the motor!
Old Nov 12, 2005 | 05:47 PM
Car: 1986 Z28
i grounded the battery is there another one?
Old Nov 12, 2005 | 05:48 PM
Car: 1986 Z28
if there is another please tell me where the hell it is lol so i can do that and start my car and race some hondas
Old Nov 12, 2005 | 05:53 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Theirs the ground wire from the battery to the alt bracket on the motor. and theirs also a ground strap, usually on the rear of the passenger side head going to the firewall. it can cause some weird problems if not hooked up.
I have seen people hook the ground wire to the post on the battery and the other end was connected to nothing, they didnt know wtf was going on lol
Old Nov 13, 2005 | 09:01 AM
Car: 1986 Z28
alright i'm gonna try that
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
