Rims with 4th gen rear
Old Nov 10, 2005 | 11:15 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
I about to order some rims for my 89 camaro. I just bought a 4th gen rear. When i order these custom rims should i tell them that i want the 4th gen specs for the rear rims? What are some of measurments i should take before i do so? thanks
Old Nov 11, 2005 | 02:41 AM
Firebat's Avatar
Tell them you want Rims to fit a 2002 camaro. That should be enough.
Make sure you get 2" spacers for the front rims.
Old Nov 13, 2005 | 07:57 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Tell them everything you've done and I'm sure they'll be able to help you.
Old Nov 14, 2005 | 01:50 AM
Frank89IROC's Avatar
4th gen wheel size
On my 1994 Trans Am, I have Torq-Thurst II wheels. The Measurement is as follows: Size: 17x9.5
5 lug x 4.75 (same as 3rd gen) Backspacing: 7 inches
Offst: 45.72mm
If you are staying with 16 inch tires then the only thing that would change is the wheel size would be 16x8.
Old Nov 14, 2005 | 10:53 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Im going with a 18x9 in the rear. I havent given the rim guy the measurments yet. remember these are going to be custom made rims for my application. i just want to get as much lip in the back. to have it look like a deep dish style.
Old Nov 14, 2005 | 11:22 AM
The 4th gen rear, I beleive is a couple of inches wider than the 3rd gen, therefore if you want deep dish wheels, the tires are going to stick out beyond the fender lip. If you don't mind that look, you'll probably have a bottoming out issue, where the tire will hit the fender on severe bumps.
Old Nov 14, 2005 | 11:35 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Yeah the 4th gen is about 1 5/8 wider and that what the guy was telling me that it will stick out more thatn the fender. I dont want that i just want it tucked in nice and neat. Im going to get about a 2" lip.. is that good enough. I just want it noticeable.
Old Nov 14, 2005 | 08:20 PM
I went to: http://www.tirerack.com
I looked up "wheels" for my 1994 Trans Am, wheel size: 18x9
they recommend an offset of: +50mm and a tire size: 245/40-18
Of course this offset size would not gice you a deep dish look, but would keep the tire inside the fender lip.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
