Mini starter for the street?
Got a 1.4 KW from Tommy Johnson's. Will this starter live on the street? I had a friend tell me today that it won't hold up to street use. This car isn't a daily driver.
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
It'll hold up fine,your friend is a dumbass.These things are designed to spin big cube engines with a ton of compression,they oughta be just fine for starting your avg.,streetable engine.
Car: 1989 C4
Axle/Gears: 307
It's basicly a gear reduction Nipendenzo with an adaptor made to fit a SBC. I dont know about you but I see more domestic starter failures then ND failures.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I was going to say that, werent they just a regular joe blow starter motor with a gear reduction.
I wouldnt see any reason why it wouldnt work, i would think it would even last longer as it takes alot of strain off the starter motor.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I need a mini starter to clear my huge header tubes. I currently use one of these.
http://store.summitracing.com/defaul...2&autoview=sku
I originally was using one similar to this. It was a cheap offshore brand. It did the job for a while but finally was having problems cranking the engine over.
http://store.summitracing.com/defaul...1&autoview=sku
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
yeah, I'm using one from a 1995 LT1, works great with more clearance and less weight to lift up when installing it..
