what is the best intake manifold gasket
Old Feb 4, 2001 | 10:03 AM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
I've got aluminum heads and an aluminum intake, is there a better gasket I should get or just go with the standard Fel-pro?
'89 Formula 383 TPI
Old Feb 4, 2001 | 10:22 AM
ede's Avatar
ede
i like fel pro, they make gaskets for iron to aluminum applications, just ask for it when you buy your gaskets
ICON Motorsports
1st & 3rd
Old Feb 4, 2001 | 11:49 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Could always get the head gaskets from GM for an '89 Vette or something. I don't know right off hand who makes GM's gaskets, but I think its Victor Rienz (sp?)
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Feb 4, 2001 | 01:21 PM
Guest
Guest
Posts: n/a
Victor Reinz... yea, thats the one GM uses. Victor gaskets incidentally are made by Dana Corp., who supplies alot of parts to GM. The packages used to be yellow and white, with black print. This, oddly enough, matches the style and colors used by Wix Filters. Wix so happens to be a division of Dana Corp. too. Ill let you figure out where AC filters come from....
Old Feb 4, 2001 | 01:50 PM
Greg's Avatar
I was actually talking about the intake manifold gasket. It will be an aluminum to aluminum application. Should the standard fel-pro gasket work??
'89 Formula 383 TPI
Old Feb 4, 2001 | 01:53 PM
Guest
Guest
Posts: n/a
Ive used the standard fel-pro.
The later Corvette (like 89) has an aluminum head and aluminum intake.
Old Dec 3, 2001 | 07:27 AM
Mike89GTA's Avatar
You can buy them from Lingenfelter's website FYI, that's where I just ordered mine.
Old Dec 3, 2001 | 10:37 PM
burnoutrpm's Avatar
fel-pro #1205
89 firebird formula
360 10:1compression (350 .060 over)/fully balnced and blueprinted
comp cams xe262 cam
performer rpm intake/port matched to heads
#1405edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner/cnc pocket ported
msd 6al/msd8.5 super condutor wires
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.73 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
griffin daul1" core rad.cutom fabrication to fit(but no cutting )
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!.with lots of NOS
Old Dec 11, 2001 | 08:41 PM
Mike89GTA's Avatar
I just bought both the 1205 Fel-Pro's and the VR ones. The VR comes with goop for the end seals and rubber seals, your choice. The also have an exhaust crossover passage and a metal chip in the rear coolant passage. The 1205's have a bigger port (taller) but no exhaust crossover and both coolant passages are open. It also comes with no silicon, just two cork end seals. Just thought some of you might want to know this.
Old Dec 12, 2001 | 12:23 AM
chevymad's Avatar
Car: 87 Formula
Engine: 327
Napa gaskets are victor.
Old Dec 19, 2001 | 12:15 PM
iroc5speed's Avatar
I use felpro without thinking twice, they know what they're doing.
Bubbajones_ya
Aug 31, 2015 12:02 PM
earlpote
Aug 28, 2015 10:42 AM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
