Moroso oil pump drive shaft in a 400
Old Dec 16, 2005 | 06:16 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
I just got home from the speed shop, got to looking over some new parts. Looked at the package for the moroso oil pump drive shaft and it said machining was required for a 400 sbc. What is up with this?
Old Dec 16, 2005 | 08:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
400 oil pump shafts are necked to clear the crank.
Old Dec 16, 2005 | 08:43 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
So I need a 400-specific oil pump drive... great. I guess i've never even seen one.
Old Dec 16, 2005 | 11:07 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Melling IS-55E
Miloden makes one as well (I use the Miloden one).
Old Dec 17, 2005 | 11:09 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Since the 400 shaft works in all the other blocks as well, most of the aftermarket shafts are similarly clearanced. I'm surprised the Moroso one isn't?
Old Dec 17, 2005 | 12:30 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
I was suprised when I saw that too, but sure enough, its not necked down at all.
Now that I think about it, the priming shaft i have is also just straight with no neck down... I hope I can prime the motor and turn it over a couple times while I'm doing so.
Old Dec 17, 2005 | 06:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That won't matter, the priming shaft replaces the distributor, not the oil pump driveshaft.
Old Dec 18, 2005 | 01:28 AM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
LOL... its amazing the things you forget in a year, that'll teach me to say something before I think about it.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
