Got the Car Back More Probloems
Old Dec 23, 2005 | 12:01 PM
RST89's Avatar
Car: 1983 camaro
Engine: 2.8...... 3.8t coming soon or should I do a ls6 almost the same cost hmmm.....
Transmission: 3spd soon to be either a 700 or t56....
Ok i have an 83 camaro with a 2.8 carbd with a 3spd auto. the problems..... It has been sitting for 8 months at a tranny shop while solving some issues. Now i have a wire that got burnt on my exaust manifold and hove no where for it to go to but now the check engine light is on and i cant pull any codes from it??? I think that is the biggest problem have no idea where it goes!! Also now when i shut the car off it back fires.... Does the car need to be " cleaned out " in other words driven or is it something else then of course it could be something to do with that wire please help me!!!! Thanks in advance
Old Dec 23, 2005 | 02:37 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
As far as the backfiring goes, check your timing and your carb tuning. If it diesels and/or backfires, typically its a combination of both. FOr the wire, look for the other end! If it was burnt in half, there should be another side. The only wire that I recall running under the headers is for the temp sensor on the block. What side was it on? If you can find it, splice the wires, run them away from the exhaust, and disconnect the battery to reset the ECM. That should clear the code, as I recall.
Old Dec 23, 2005 | 06:29 PM
RST89's Avatar
Car: 1983 camaro
the wires are on the passenger side i have searched and searched for the other end if whatever it was connected to has to be a plastic connector its two wires loomed togeather. I tried reseting the computer didnt work i even bought a bran d new computer and that didnt fix it either im totally lost but it is affecting my car i wish i could get some sort of code out of the darn thing any ideas thanks
Old Dec 29, 2005 | 08:14 PM
RST89's Avatar
Car: 1983 camaro
no solution yet please help me thanks
Old Dec 29, 2005 | 08:28 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
What color wire and where does the one end go to?
Old Dec 29, 2005 | 08:49 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
sounds to me like it's the O2 sensor. Thats probably the only thing I can think of with a wire that connects to the exhaust manifold
Old Dec 30, 2005 | 06:24 AM
RST89's Avatar
Car: 1983 camaro
ok guys i cleaned my engine bay today and found where the wires go. i have all that smog crap on my car and on the passanger side there are vacumes and cylinder looking things there the only problem is there are two wires i dont know which one goes where i belive its one positive and one negative i plug them in both ways but did not really tell any difference and also the check engine light didnt go off???
Old Dec 30, 2005 | 08:56 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The air diverter valve will not give you the CES light, so it must be something else.
Double check your wire going to the O2 sensor.
Old Dec 30, 2005 | 04:53 PM
RST89's Avatar
Car: 1983 camaro
i checked all my wires and everything is good to go the ces light came on when the wires melted against the manifold and has not gone of since. my car is starting to idle rougher and get very bad gas milage what could it be?? i know that this is where the wires go there is no where else rfor them i just dont know which one goes on whic side + - wise buit other than that my car is still pooped out and i dont knwo why the ces light is staying on and my car is idling so rough and my gas milage is so bad???/
Old Dec 31, 2005 | 03:04 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Did you replace the burnt wires?
Old Dec 31, 2005 | 03:48 PM
RST89's Avatar
Car: 1983 camaro
the burn wires plug into some sort of thin for the smog pump i tried plugging them in there are two ways to do it and neither made any difference. so yes i did replace them but no change the check engine light didnt go off either.
Old Jan 1, 2006 | 10:06 AM
RST89's Avatar
Car: 1983 camaro
k still havent done anything with my timing but i did find a very large vacum leak so that fixed the probem of almost stalling from a dead stop to WOT but the car is still dieseling as far as still sucking to much gas i dont knwo yet i will let you know on that later. so is it my timing or is my car running to rich??
Old Jan 1, 2006 | 02:51 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Too much timing can cause dieseling, but usually will also cause the engine to turn very slow when starting. It's normally a vacuum leak causing a lean condition.
Don't forget that having the idle speed set too high can also cause dieseling.
Old Jan 1, 2006 | 04:01 PM
RST89's Avatar
Car: 1983 camaro
the idle is definatly not to high when i found the vacume leak this morniing it was a open tpipe on the driver side rear so i am assuming that something had to of onnected to that so i will look for that then i will try the old propane trick thanks in advance keep it coming
Old Jan 1, 2006 | 04:58 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Let me rephrase.
Your idle speed could be low because of poor running even though the throttle angle is excessively open.
A large vacuum line on the rear usually goes to the power brake booster.
Old Jan 1, 2006 | 08:31 PM
RST89's Avatar
Car: 1983 camaro
sorry the vacum line runs right next to the brake booster it is not quite that big it is probally half that size.
Old Jan 1, 2006 | 10:50 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
You could plug the vacuum lines at the source on the intake and see if the problem goes away.
Old Jan 2, 2006 | 07:12 AM
RST89's Avatar
Car: 1983 camaro
ok ill give that a try also i dont know where it goes yet i will look this morning and let you guys know what i find
Old Jan 5, 2006 | 07:07 AM
RST89's Avatar
Car: 1983 camaro
ok i have all the vacume line correctly connected now it seemed to oh helped a little but still didnt fix the deiseling problem i am now smelling something like maybe gas in the car an unusual smell for my car does anyone now how to adjust the oem 2bl carb for a 83 2.8?? or any other suggestions?
Ghettobird52
Jul 5, 2024 11:18 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
