Wow man 10 minute job into hours
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
I never knew chaning this fuel filter on my car would be such a bit of work. The bolts are rounded off on the fuel lines so I have to use vice grips and a wrench. I lubed it up and let it sit and I finally got the side off going to the tank. I cannot get the other side off. I sprayed it and I am going to let it sit overnight. Do you think it will break loose in the morning? What are some other tricks? Thanks guys.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
a torch....and i'm kidding.
honestly they're always a pain, once you get them to finally break loose, put some never-seize on the threads to make next time around much much easier. remember that you can put all the pressure you want on the fuel filter's threads, because those being rounded off will be replaced by a new fuel filter, just don't kink the fuel line while attempting it. They always end up rounding off after a few years of road grime/salt anyways.
Oh yea....use never seize x2 so it doesn't happen again
Engine: LB9, LB9
Yeah once the line started to flex, I didnt apply as much torque. Also its the nuts on the fuel line that are rounding off so it sucks bad.
Engine: LB9, LB9
Wow man after letting it soak, it didnt help and now the bolt is VERY rounded off. What is something I can do lol. How much is a new fuel line?
Car: 1992 z28
Engine: Vortec 350 TPI
Since the nut is rounded off, you might try holding the other nut with your vise grips and get something to turn the filter, instead of trying to turn the nut.
Car: Pair of 92 Z28s
yup i twisted the line it kinked it and broke it in half finnally. It was much easier making a new section that goes to the filter. From the filter to the engine that line remained the same. My car i did it in under 15 mins on my gf's car it was 2 days replacing the filter.
Also what is so funny how rusted this car is. I kinked the brake line going to the wheel cylinders and now yesterday replacing the radiator it kinked the transmission cooler line. All this **** has delayed me so much from just fixing it and getting it on the road. Oh well
Engine: LB9, LB9
I got it finally, it was tough though. I guess everyone that tells me WD-40 is baby stuff is right lol.
Car: 1985 Chevy Camaro
Engine: 350 2-bolt
Axle/Gears: 10 bolt, 3.23 posi
WD-40 is baby stuff, years of messing with imports in limited room to use my fat hands (an tools), I found that ATF +3 in a metal spray bottle works MUCH faster and better.
