It's taken me 13 years to figure this out
Old Dec 25, 2005 | 12:36 AM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
I have always noticed since i bought my car wayyyyyy back in 92'
(yea $14,999 brand new)when you go to put the car in reverse 98% of the time it always makes that grinding noise. I've made sure i've been to a complete stop,even set there for several seconds waiting and then, there's that grinding noise going into reverse. I have now finally figured out that if i come to a complete stop, put the car in fifth gear then go to reverse,presto...no more grinding noise. Anyone else ever have this problem also or was it just a curse?
Old Dec 25, 2005 | 12:57 AM
85_Camaro_Kid's Avatar
Car: 1985 Chevy Camaro
Engine: 350 2-bolt
Axle/Gears: 10 bolt, 3.23 posi
Re: It's taken me 13 years to figure this out
I remember when I was little my dad had a 87 blazer, and it did that (bought it new too!). Sorry, I didn't contribute much, just though I would share.
Old Dec 25, 2005 | 06:57 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
I think it was common with alot of T-5 trannys or gm trannys in general to do that. Ive driven a few S-10's and camaros that putting it into 5th gear stopped it from grinding going into reverse. Its a syrnonizer thing .
Old Dec 25, 2005 | 08:18 AM
Scheister's Avatar
Car: 85 IROC
i do that on all the cars i have, force of habit. i started doing it on a civic and noticed it was easier to get into reverse on other cars aswell. such as a porsche, and rx7
Old Dec 25, 2005 | 10:40 AM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
The reason the T5 in your car does that is because reverse has no syncros. So if you put it in any of the forward gears (which have syncros) then it will go into reverse without grinding.
Old Dec 25, 2005 | 01:58 PM
Engine: 350 2-bolt
Accually from honda transmission experence and having rebuilt one, before going into reverse, go N-1-2-1-R. Int the RX-7 I used to own, I found it easiest to got to 5th, then reverse.
Old Dec 25, 2005 | 08:31 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
My old 86 5-speed would ALWAYS grind in reverse. I would have to put it in first to bring down the rpms then push the clutch back in and quickly shift into reverse.
Old Dec 25, 2005 | 08:34 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
My 94 s-10 does the same thing... put it in any forward gear, no more grinding!!! I usually put it in 1-N-R.
Old Dec 26, 2005 | 11:59 AM
87tpi7749's Avatar
Car: 1987 Iroc, 1987 MCSS TPI
Engine: 5.7L
Transmission: 700R4 in both
The reason it grinds is because the main shaft is still turning when you depress the clutch and reverse has no synchro, so by putting the tranny in any gear, you stop the main shaft from turning and easily slide into reverse. Most of the time a roller pilot bearing solves this problem, which is why GM now uses them. A big mistake most people make when doing a clutch job is they use some sort of grease on the bronze pilot bushing, grease is not the correct lubricant, it causes severe heat and galling, usually makes the problem worse. Always remember to lube bronze pilots with motor oil.
Old Dec 26, 2005 | 07:51 PM
Car: ws6
Engine: ls1
Transmission: m6
Man did GM make some crappy Trannys. A lot of the T-5's would grind. Also they cant handle much over 300 lb ft of torque. I think my 700 only can handle something like 400 horsepower.
Old Dec 26, 2005 | 08:39 PM
Vader's Avatar
FWIW, GM didn't make the T-5. Borg/Warner (Now Tremec) did. Some of the Saginaw and Muncie transmissions (made by GM) were actually fairly stout, if not very smooth. AFAIK, GM is now only directly involved in the Getrag and New Process Gear units, plus all the automatics they make for everyone.
Old Dec 26, 2005 | 08:42 PM
Car: ws6
Engine: ls1
Transmission: m6
Well they definitly improved since then. The trannys in the LS1's are waaaay better.
Old Dec 26, 2005 | 09:09 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Tremec.
Azrael91966669
25
Jun 20, 2017 04:04 AM
1986Z28OWNER
Dec 13, 2015 10:19 PM
lt1z350
Aug 28, 2015 05:57 AM
michealleger
Aug 26, 2015 03:29 PM
Fronzizzle
Aug 9, 2015 01:15 PM
