trick flow heads and pro magnum 1.6 roller rockers
Old Dec 30, 2005 | 06:53 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
anyone have this setup? did you find any problems with them?
i have the trick flow twisted wedge heads, and when i put on my comp cam pro magnum 1.6 roller rockers my intake/exhaust are VERY close to eachother, almost touching
did anyone have this problem with theirs?
because i just started the car tonight after just putting these in, and im getting a clicking noise under the valve covers, and im guessing its the roller rockers.
unless they are hitting the studs again like my other rocker arms did, thats why i changed.
Old Dec 31, 2005 | 01:07 PM
Mark 89Formula's Avatar
https://www.thirdgen.org/techbb2/sho...hreadid=120582
https://www.thirdgen.org/techbb2/sho...hreadid=224322
I'll say up front that I don't have the Twisted Wedge heads but have considered them a couple of times over the years. I think you'll find the info in the two posts above very helpful. In them TFS says the Pro Magnums are compatible with the Twisted Wedge heads. I've read other posts saying these rockers are noisier than other roller rockers, so maybe that's all you're hearing. If you search for posts by "Artie@TFS" you'll get a couple of other posts you might want to read.
Old Dec 31, 2005 | 03:42 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
thank you very much, i guess it does show he "recommends" these rocker arms for my heads, but they are SO close together, they are touching it looks like. and they are noisy, but its a ticking, its very loud if you stand away from the car, im not sure if this is what they are suppose to sound like or not.
thanks tho i will look up his name
Old Jan 1, 2006 | 12:13 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i wrote Artie@TFS an email ill await his response, but id like to hear from other TFS twisted wedge owners and the rockers they used, preferably if they used CC pro magnum 1.6 rr's, if they had any issues of the rockers so close they are almost touching.
Old Jan 3, 2006 | 04:50 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok he wrote me back, and is helping me out i just had to send him these pics, but i wanted to show you guys what i meant.
Old Jan 3, 2006 | 08:39 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
well i was searching google, and on summitracing.com and came across a set of these.
1309-8 Chevrolet V8 265-400
Twisted Wedge Head, Intake Valve
3/8” 1.6
these are made for trick flow twisted wedge heads, it didnt give me any information AT ALL the specs on these, but im assuming they would be not as wide as normal comp cams pro magnum, im not sure of any other reason.
i have a set of the 1302-16, anyone know?
Old Jan 3, 2006 | 08:41 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
The ticking is probably your valve lash. Those do look very close together though. Heres mine with crane energizer rr
Old Jan 3, 2006 | 08:49 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
wow yours have alot of space, i wonder why mine are so close? thats screwed up.
and well my valve lash, i shut off the motor and took off the valve cover, and all rockers were nice n snug did not move around at all, so im assuming none came loose.
only thin i can guess is the ticking is the rockers hitting, and i MUST have the wrong rockers, but i was told by numerous people that these rockers were compatible with twisted wedge heads, im stumped, and dont want have to buy another set of rocker arms.
Old Jan 3, 2006 | 09:47 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
stainless emits more noise.
Old Jan 8, 2006 | 03:22 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok well here, i video taped the motor running, can someone tell me if these comp cams pro magnum 1.6 rr's are normally this loud? or is it something else.
to get the video, click the link, wait for the 15 seconds to go, then it will provide 3 or 4 links to download it at, someone please watch and comment if this is normal. i know there are setups out there similar to mine, or even how the comp cam pro magnum 1.6's sound.
the link doesnt work, i can send it to someones email or send it over msn, my msn is roughskinjrz@hotmail.com
Old Jan 8, 2006 | 08:38 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
That sounds too noisy to me. Pull a couple of them and inspect them. If they're hitting you will see signs of it on the rocker.
Old Jan 8, 2006 | 08:51 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
thats what i thought, i had the valve covers off, they werent hitting the rocker studs, or the head bolt, so i have no idea what could be wrong. ill take a few off tomorrow as see if there are any scratches or marks anywhere.
Old Jan 8, 2006 | 11:36 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Those look like the standard 23* TF heads, not the twisted wedged ones.
Old Jan 9, 2006 | 10:20 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
yes, i was curious to, they arent on the same angle as mine.
Old Jan 9, 2006 | 11:38 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Pro-mags are pretty wide rockers. Best bet would be to turn the engine over by hand and inspect all the rockers to see how close they really get and if they touch while in motion. From the pic, though, they look REALLY close to eachother.
Old Jan 9, 2006 | 12:20 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
well if they do touch, what will i have to do, get new rockers, isnt there pro magnum's i can get specifically for the intake side of the twisted wedge heads? would be be not as wide so the rockers wouldnt hit, while the motor was running i checked the rockers they werent hitting the rocker stud of head bolt so only other thing i can figure is they are hitting eachother that what the ticking is.
Old Jan 9, 2006 | 12:42 PM
rolling-robert's Avatar
Car: z-28 x2
Engine: 355ci and 305ci
Transmission: th350 and th350
You have a PM
Old Jan 10, 2006 | 09:51 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
ok i actually have a video for all to see, finally working:
http://videos.streetfire.net/Player....C-BABD655B3AB8
let me know
Old Jan 10, 2006 | 03:59 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
My bad, I had a few windows open and guess I missed the fact that he has the twisted wedge heads From the video, that sounds like some nice valve lash. I would think that the rockers hitting would sound a little worse. Pop the valve covers, start it up, and slowly tighten each rocker. See if the noise goes away. Just don't rev it up or you'll end up with an oil mess.
Old Jan 10, 2006 | 04:18 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
well i followed your advice and did ANOTHEr valve lash, ticking is almost completely gone!! instead of a multiple tick, its coming from just one spot on the driverside so im guessing i have to check one rocker, thanks alot, motor sounds awesome without the ticking!!!
Old Jan 10, 2006 | 04:23 PM
csa000's Avatar
Car: 1989 IROC
Transmission: 5 Speed
have you looked at the valve covers? those rockers do look awful close but they could also be hitting the inside of the valve cover. that makes a lot of racket
Old Jan 10, 2006 | 04:44 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
yeah i took off the roller rockers and not even a SCRATCH on any of them, so it had to be the valve lash
Old Jan 11, 2006 | 03:15 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Mine took a while to get set right. Make sure that you have the set screw out far enough so it doesn't bottom out against the stud. I set mine by loosening until it just started to tick, then tighten 1/2 turn past where it stopped ticking. Did this for each rocker.
Old Jan 11, 2006 | 03:43 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
they are all tight, but im getting an awful tick on the driver side only, it may be a rocker but i dont think so, feels like metal slapping metal
Old Jan 11, 2006 | 03:45 PM
85z28guy's Avatar
Car: 85' Z28
Engine: 383 roller
Maybe you should stop running it then. Could be an exhaust leak, but a metal on metal sound is never good It makes the noise even with the valve covers off right?
Old Jan 11, 2006 | 04:57 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Correct me if I'm wrong but that close part of the rocker (trunion) doesn't even move, so why would it be making noise? Unless of course they are wedged together from tightening the lash causing a valvetrain misalignment. I would loosen them completely off one cylinder at a time and make sure they are all the way down on the stud before you start to tighten. Its possible as you start to "pull them down" they (trunions)are wedging against each other misaligning the valvetrain. I wouldn't run it anymore until you figure it out. I think the trunions are to wide for the twisted valvetrain.
Old Jan 11, 2006 | 05:35 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
yeah well all the ticking is gone, but this is a slap it sounds like but when i rev it goes away
Old Jan 12, 2006 | 03:26 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Make sure you have the correct length pushrods. They are a custom length for the intake side. You can wipe out a set of guides in the Twisted Wedges very quickly if you don't have the correct geometry.
Twisted Wedges require a narrow bodied rocker. Of course, Trick Flow recommends thier own but a lot of guys I know are using the Comp Cams Magnum roller tips and for going the cost of a fully rollerized rocker. To my knowledge, all the Magnum roller tips for SBC will work including the self aligning.
Old Jan 12, 2006 | 05:31 PM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
well i used a pushrod checker and im pretty sure its right, lol!! also i was told BY trick flow and people on this board CC PM 1.6 rr's are recommended for these heads, i set the valve lash and all the ticking has gone away
midge54
Dec 27, 2019 04:14 PM
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
