which rod an main bearings
Car: 96camaro ss,87z28, elcamino,68 firebird
Engine: which car ?
Transmission: most likely a manuel
hey every one , what are the diffrence between the bearings that are out there on the market ? is one relly better than another ? what are the good ones ?
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Quality control, materials, things like that and yes, there are differences.
I prefer Federal Mogul. From what I have read, Clevite, in the past, has had some QC issues.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It really depends on what you want and how much you're willing to spend. I personally like Clevite 77 bearings. You could also go to your local parts supply store and buy generic, off shore, off the shelf bearings and they'll last or fail at about the same rate.
Engine: which car ?
Originally posted by stroker_SS
Are those different then the Clevite 77 "H" series?
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
My machine shop said that since I was sticking with the stock crank to use the P bearings. He said the H were overkill for my setup. But I really dont know what the differance is.
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
