choppy idle
Old Jan 17, 2006 | 09:58 PM
muteboy49's Avatar
Car: 84 Camaro
Transmission: dont have one yet
Axle/Gears: 3.42 spool on the way
choppy idle
im buying a cam with a .488/.488 lift with a 292/292 adverrtised duration.
will this cam give me a choppy idle?
Old Jan 17, 2006 | 11:05 PM
muteboy49's Avatar
Car: 84 Camaro
nobody???
Old Jan 18, 2006 | 12:07 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
What motor? What are the rest of the cam specs?
Old Jan 18, 2006 | 12:12 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i have a bigger cam in my 305 and i'm going to have to say that it will have a slight lope but nothing like a 550+ lift cam would have or larger. I'm sure it's 292 advertised duration but no where near that at .050 where most cams are rated.
Old Jan 18, 2006 | 08:49 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
the way a cam sounds is the last thing you should be worried about... pick something that suits your engine not your eardrums.
Old Jan 18, 2006 | 02:12 PM
muteboy49's Avatar
Car: 84 Camaro
this is the cam that someone told me would compliment my motor quite well
Old Jan 18, 2006 | 05:51 PM
ljnowell's Avatar
That cam will have plenty of a choppy idle in a 350. Trust me. The lift has nothing to do with the sound. However, picking a cam based on sound really isnt a sound idea.
Old Jan 18, 2006 | 06:10 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
is it EFI? Carb? What? You're someone may or may not be correct.
And I'm with the rest of the people who say go for overall performance of the engine, not the sound output.
Old Jan 18, 2006 | 06:23 PM
muteboy49's Avatar
Car: 84 Camaro
haha i really dont care what it sounds like. this is just a random question. its carbd. the guy had almost the same setup as i do and his car (which was a third gen) ran real well.
thanks guys
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
