Car wont turn over
Old Jan 28, 2006 | 07:02 PM
SydwayzTA 86's Avatar
Car: 1986 Trans Am
Engine: 5.7L TPI
Car wont turn over
Hi, I converted my car to a T5 from a 700R4, and i belive i got everything in, the motor was swappd before this trans swap also, but it did attempt to turn over with the 700R4, now i dont get anything when i turn the key, the car does seem to have power, the lights and everything work. Any thoughts ?
Old Feb 1, 2006 | 11:45 AM
Car: 1986 Trans Am
Engine: 5.7L TPI
anyone ?
Old Feb 1, 2006 | 12:19 PM
jsel's Avatar
Car: 1989 iroc conv
Engine: L03 TBI
Transmission: 700R4 soon to t5 from hawks
test your battery just because the lights work your battery still may not have enough power to turn your car over
Old Feb 1, 2006 | 02:38 PM
jsel's Avatar
Car: 1989 iroc conv
Engine: L03 TBI
if the battery is good make sure that your transmission safty switch is hooked up or cross the switch!
Old Feb 1, 2006 | 02:42 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
the battery is brand new, and has been tested. where is the tranns safety switch
Old Feb 1, 2006 | 08:07 PM
jsel's Avatar
Car: 1989 iroc conv
Engine: L03 TBI
ok i think that when you removed the 700r4 you should have removed the wiring harness from the shifter being an auto the transmission had to be in neutral in order to start and not in gear so when you replaced with a manual trans the safty switch is at the clutch pedal which has to be pressed down in order to start find the wires that you removed from the auto cross the switch wire this is called a neutral start switch try to get a haynes manual to find the correct color wire.
Old Feb 2, 2006 | 02:09 AM
Car: 1986 Trans Am
Engine: 5.7L TPI
ok great, thanks for the help, i gotta rebuilt my tranny right now anyway, but once i put it back in i'll try that, thanks a bunch
Old Feb 3, 2006 | 10:37 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
look under the steering column there should be a set of wires on yellow and one purple they need to go to the clutch pedal so the car will start you will need to have a clutch pedal switch installed or you can jump the wires and the car will start in gear and risk the chance of hitting something
goodluck if you can't find the wires i can email pics
Old Feb 4, 2006 | 03:19 AM
Car: 1986 Trans Am
Engine: 5.7L TPI
pics would be great, could u email them...
walter.blackburn@advanteck.net
thanks a bunch
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
B_Dubya
Aug 26, 2015 05:09 PM
Fronzizzle
Aug 9, 2015 01:15 PM
