spark plug hole striped!
Old Jan 29, 2006 | 02:00 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
like it says the drivers side spark plug 3ed in is striped (hardest one to get to) the good news i didnt do it, but i still have to fix it, i was thinking better heads but im in the middle of a turbo build so thats out because of money so i was thinking this
http://www.thetoolwarehouse.net/shop/HEL-5334-14.html
dose the SBC have a 14mm spark plug? and what
insert would i use because this kit comes with 3 diffrent. thanks for your help
Sean
Old Jan 29, 2006 | 04:56 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
i dont think it matters what size the threads are as long as the plug seals the head. as for which lenght to use, i'd use the one that has the same thread lenght as a spark plug.
Old Jan 29, 2006 | 05:18 PM
ede's Avatar
ede
SBC is 14mm
Old Jan 29, 2006 | 05:37 PM
high c's Avatar
Car: 86 iroc
thanks for the replys ede and SaintedCorrupt
Old Jan 30, 2006 | 01:57 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
They sell those sleeves/adapter kits at any parts store for like $15. Basically you'll make new threads and a bigger hole. Then you put the sleeve in it. Then reinstall the spark plug. Not that hard really. Had to do it to my friends Thunderbird like 2 weeks ago.
Old Jan 30, 2006 | 02:04 AM
Car: 91 RS
Engine: 350 TBI
Looks like this:
http://www.timesert.com/html/howtosp.html
Old Jan 30, 2006 | 06:22 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I would use a helicoil... if you use one of those non-foulers you will make it harder to get to the plug because it would stick out more and could complicate things. a Helicoil is a permanant fix and make the threads better than they were before.
Old Jan 30, 2006 | 06:26 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Its too bad you cant really keep the shavings from tapping the threads from going into the heads....
Old Jan 30, 2006 | 06:14 PM
high c's Avatar
Car: 86 iroc
pics are so much easyer to use then reading... i did end up going with the helicoil just because the napa in town hade it in stock, it was kinda pricey but comp. to new/used heads the pricing was great
Old Jan 30, 2006 | 09:02 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
You mean down the cylinders when it is on the engine?
Oh yes you CAN!!!
My motto: "If you want to know the easiest way to do something,
ask the laziest guy"
(for some reason I have a lot of answers)
You are supposed to pull the head to retap the sparkplug hole. That's a lot of work. If it's an iron head it's really important, and no, covering the tap with grease won't keep the chips from falling into the cylinder.
I figured out a way to keep the chips out of the cylinder and
NOT have to pull the head.
It's easy. Close throttle butterflies completely (screw out the idle screw).
Rotate the engine until the intake valve on that cylinder is open.
(you wiseguys know how to do this by pulling the distributor cap and not the valve cover)
Remove the pcv valve and connect shop air to the hose to the intake.
You now have a hell of a breeze blowing out of the sparkplug hole. Wear safteyglasses because those chips coming off of the tap will be hitting you in the face instead of going down the cylinder.
Old Jan 30, 2006 | 10:22 PM
high c's Avatar
Car: 86 iroc
Thats some great info!! ill will deff have to give that a try when i fix the plug
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
