Not much to do with thirdgens but it's amazing.
Old Feb 5, 2006 | 11:29 AM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
This new transmission is said to improve gas mileage by 20-30mpg: http://deseretnews.com/dn/view/1,1249,635179379,00.html
Old Feb 5, 2006 | 04:17 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Yea... it's a manual trans with a whole lotta gears (infinite??).
Big rigs have been using transmissions with a lot of gears for a couple of years, at least.
What makes this one so special?
Old Feb 5, 2006 | 04:25 PM
IROCZ86's Avatar
Car: 96 SS #15
Engine: LT 1
Transmission: M6
Axle/Gears: 3.42 ZT
Great find, should be in the transmission forum though.
Old Feb 7, 2006 | 12:26 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Can we say CVT transmission?
Honda's been using for a while, no fixed gearing. Infinite possibilities for necessary gear reduction.
Old Feb 7, 2006 | 12:46 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
CVTs use rubber bands though, this is something different.
Old Feb 7, 2006 | 01:20 AM
EvilCartman's Avatar
Car: '82 Z28
Should have seen the Volvo with twin belt drive Just like a go-kart, but it had 2 vacuum operated pullies and all kinds of other weird stuff. Wish I had my camera at the time.
Old Feb 8, 2006 | 09:29 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I'm sure not smart enough to figure out how cams can evenly transmit linear power. Guy might be a genius, or a crackpot.
Old Feb 9, 2006 | 12:48 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I don't really get it either. But i guess that makes sense. How does it work? If this was really a good simple idea that worked we would have them already.
Old Feb 9, 2006 | 08:18 AM
Vader's Avatar
I believe "we" do. Outside the automotive world, similar transmissions have been used for decades. Initial analysis of this unit appears to reveal a striking similarity to ZeroMax industrial power transmission units. They use a reciprocating cam/lever/clutch arrangement with "infinite" range. The belt/box CVTs that Swedish Ford and Honda have recently touted as "innovative" have been in use in the U.S. since the 1930s. Similar PIV chain drives have been in use before WWII. Disc/ball speed variators are (or used to be) very commonplace infinite transmissions.
There are all manner of constant HP, constant torque, and constand speed drives in use, just not in the automotive field. And CSDs have been in use in aviation since the 1940s, using "infinite speed range" devices. Woodward, Hamilton, Sundstrand, Cleveland Gear, and many other manufacturers have made them for decades. Now, apparently, the rest of the world has caught on. My understanding is that once a vehicle is in motion at a constant rate, engine speed variation is minimal, and a well designed torque converter (a.k.a., hydrostatic variable speed drive) is used for the minor load changes at constant speed.
These "geniuses" are trying in desperation to stretch the life of a dying technology. The ultimate personal vehicle will eventually not have an internal combustion engine, but a traction servo at each wheel. Some manufactureres are already there, GM being among them.
Now, apparently, they are all the rage.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
Exxon Limited
Aug 9, 2015 08:13 PM
