what heads to use ?
Old Feb 28, 2006 | 12:49 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
what heads to use ?
new build is a 92 350 l98 rebuilt stock bottom end. 9;3;1 .will be using performer rpm intake and carb with hei. th400 tranny stock converter and gears, for now.
my question is what heads would be best for just weekend street racing, this car is my toy, not a daily driver or race car. heres my options.
083- that came on motor. any potential here ?
416- 305 heads i have sitting arround.
441-just rebuilt with manley valves, comp springs, screw in studs. teflon seals,ported and guide plates.
built the 441 heads for motor that i blew up, they are 76 cc +/-. will this kill my comp. ratio.
416 are 58 cc and need the whole 9 yards, 083 i have no experience with.
or take all parts off 441's and buy a set of bare castings ? suggestions on a good set ?
also trying to to stay budget minded. (spent my wad on 441's)
thanks, mike.
Old Feb 28, 2006 | 01:01 PM
teapot3208's Avatar
Car: 1985 Camaro
Engine: 350 .030 over (355)
Transmission: 700-R4
If you wanna use the 441s, you could use those thin head gaskets to bump the compression up a tiny bit.
Old Feb 28, 2006 | 01:07 PM
083 is a decent head.
I'd suggest working them up similar to the 441s; and moving all that hardware over to them.
Old Feb 28, 2006 | 01:34 PM
SPIKE's Avatar
Car: 86 CAMARO
sofa, mods to 083's
port and polish.
manley 1.94/1.5.
valve job.
comp springs 981-16
teflon valve seals.
pin studs or machine for screw ins cam lift is .48 to .49 ?
1.6 roller rockers.
sound good ? any thing else without breaking the bank ?
head gasket recomendations ?
Old Feb 28, 2006 | 01:58 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you've got a 76cc head, a 64cc head, and a 58cc head, what are you using to calculate the 9.3:1 CR of the engine
maybe use 1.5 rockers, and just pin the studs.
if you go to a 1.6 rocker, you may have to elongate the pushrod slot, and then you may screw it up, so then you might have to drill it out huge, and run guideplates, so then you'd have to pull your rocker studs, tap the holes, mill them down, buy guide plates, and collared threaded rocker studs. Then hardened pushrods for the guideplates of course.
Option 1 is easier, and you don't 'lose' anything really.
Old Feb 28, 2006 | 02:08 PM
SPIKE's Avatar
Car: 86 CAMARO
sonix, 9;3;1 was with stock 083 heads 64cc, that came on motor. they had 1.6 rr's. on them.
wasnt sure if 58cc would put me to high, or 76cc to low.
Old Feb 28, 2006 | 02:16 PM
Sonix's Avatar
Car: 1982 Trans-Am
9.3 is a good place to be. The other heads would move that to an undesireble CR, IMHO, so I think the 083s are your best bet.
Old Feb 28, 2006 | 02:17 PM
SPIKE's Avatar
Car: 86 CAMARO
while on this subject can someone give me a basic lowdown on the advantages or disadvantages of going 1.5 to 1.6 rollers ? only reason is the motor with 083's on it was running 1.6's and i havent bought a new set yet.
Old Feb 28, 2006 | 03:11 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
The 1.6 gives you more lift from your cam than the 1.5. It also reduces the amount of travel for the valve train to gain those higher lifts.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
