gains from ported edelbrock base to unported!?
Old Mar 4, 2006 | 10:29 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
well i have an unported edelbrock base on my motor now but i was wantin to know how much more of a gain could i see from doin somthin like this to it? http://www.eecis.udel.edu/~davis/z2...113baseporting/
also im runnin the parts in my sig! just want to know if its worth the trouble or not!! thanks
Old Mar 5, 2006 | 12:02 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
A ported/Extude Honed base will flow 270CFM. I believe the stock Edelbrock base flows around 240cfm maybe a little less. So figuring 2.0156 horsepower per cfm that is a gain of 60 horsepower. That is considering your motor to be 100% efficent but it is not so gain would not be that high. The flow with your heads and the intake manifold attached will be less.
Old Mar 5, 2006 | 12:53 PM
Car: 92 1500p\u 2wd
and these numbers are from an edelbrock base or a "stock base"
Old Mar 5, 2006 | 01:29 PM
Car: 1989 GTA
Engine: 369 TPI
Edelbrock base.
Old Mar 5, 2006 | 04:23 PM
Car: 92 1500p\u 2wd
man thats a lot....so its worth it then!!
Old Mar 5, 2006 | 07:09 PM
Car: 1989 GTA
Engine: 369 TPI
Only if the rest of your combination can use the extra flow will you see a big gain. Heads, cam, exhaust and air intake. It all has to work as a package. It won't hurt anything to do it.
Old Mar 5, 2006 | 09:42 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
If your base flows 270 and your heads flow 220 then your base will only flow what your heads need so the porting of the base from 240 to 270 is pointless. To get the max power from a base mod then you will need some good flowing heads for max power.
Old Mar 5, 2006 | 10:53 PM
Car: 92 1500p\u 2wd
alright so what if i put on some ported 113s or afrs"180-190s" if i do this portin on the base it will be when i swap on better heads!
Old Mar 10, 2006 | 11:44 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
if you put on better flowing heads with a better flowing intake, you get more air=more power
Old Mar 11, 2006 | 11:05 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
AFR 195cc heads will flow around 260cfm @ .500" lift. With those heads, it could be worth it to port the base. The corvette heads though, flow considerably less than that.
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
mrestrictrplate
Sep 21, 2015 11:24 AM
eustodp
Sep 20, 2015 05:09 PM
Rally Smith
Sep 14, 2015 06:59 PM
toronto formula
Sep 10, 2015 07:31 AM
