Would 305 heads be an improvement on a 350?
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
I am looking at buying a rebuilt 87-95 350 for my ride to rplace my trashed LO3 motor. The 350 motor is a stock rebuilt 350 with a block casting number of 14093638 wich is a 2 bolt main I think. It has the 193 casting number cyl heads. I was told by the shop it has 8.5:1 compression ratio
I Have a set of nearly new World Products 305 S/R torquer cyl heads. Would they be an improvement over the 193's?
Would they raise the compression to high for 87 pump gas?
Or should I sell the Torquers and look for a different set of 350 heads?
Transmission: 4L80E/4L80E
Self-ported World Castings S/R Torquer 305 heads (turned out to have 64cc chambers even though I didn't do any unshrouding, just polishing), Speedpro .030"-over 10cc dish/relief hypereutectic pistons, block decked .012" (put the pistons .026" down in the hole), .020" thick Victor Rienz head gaskets. End result is 9.7:1 static CR.
Runs fine on 87 octane unleaded and 10 degrees base timing. Track #'s indicate something in the neighborhood of 365 gross flywheel HP.
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
My other option is selling them and getting another set.
I see a few vendors on e-bay now with good feedback selling 416 and 434 casting heads for 400 bucks a pair. They have larger valves 2.02 and 1.6. Would these be better than the world's? I could probably sell the world's for close to 400 to offset the costs.
What do you think would be best?
And in respose to above the motor does have the cheap non flattop cast pistons. They said they use Elgin brand stock replacement pistons.
Out of all those options, the World heads are the best. They would be better than any of the stock ones.
You might want to look at a cam while you've got it apart. A typical "rebuild" will have a 929 cam in it. Just about the bottom of the barrel, for performance. Major improvements can often be made there, for not too much $$$. Take a look and see if it's a roller before you order anything. Probably not; but you never know for sure until you look.
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
So the World heads would be better than a set of 416's with the larger valves? Is that because the Worlds have better flow even with smaller valves?
I do have a better cam to use. My brother gave me one he was going to use in his truck. It is a 4x4 truck cam so it will have good tourqe. I'm not going racing so I'm ok with the top end not being real strong. Its is new and comes with lifters and a timing chain, best of all its free. The rebuilder also said he would knock off 100 bucks when I told him I did not need the cam, lifters and timing set.
Car: transam, el camino
Engine: 415
305 heads do not belong on a 350, world heads or not. Sell em and get some 350 heads.
NinjaNife
Aug 23, 2015 11:49 AM
