Car stalls and hits a wall at 2500rpm, help?
Old Apr 10, 2006 | 09:04 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
My CCC 85 z28 has been shutting off when going 25mph, while breaking for a turn, and frequently shuts down at idle speeds. It also hits a wall at 2500rpm when accelerating. It will bog down and then if you continue to press into the throttle eventually stumble on.
Could this be a coil issue? I have the accell high output HEI coil (how old i dont know). The cap and rotor are new.
Old Apr 10, 2006 | 10:36 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
How old is the fuel pump? (very common cause of high RPM bogging and pinging with these cars) A dieing fuel pump has a hard time keeping the fuel bowl full in the carb, and it runs out of fuel at high rpms.
Have you checked the TPS voltage?
I had a problem with my cc qjet before with a eratic idle that would dip down sometimes killing the engine at idle and low rpms and it ended up being a broken TPS sensor giving constant low readings.
Old Apr 10, 2006 | 11:15 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Well it dies most at low rpms, like when switching out of reverse to drive. Just cuts out, doesnt sputter. I can replace the fuel pump, i dont know how 9old it is, but I would like to test the coil, or even see if its a relevent reason.
Old Apr 11, 2006 | 06:00 AM
thefightback's Avatar
Car: 86 Z28
Engine: '90 350 TPI
Transmission: T700
similar thing happened to me. replaced MAF which fixed it. just a guess though.
Old Apr 11, 2006 | 07:40 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Clogged exhaust or broken cat? Have had both with similar results as yours.
Old Apr 11, 2006 | 07:33 PM
x_wolf's Avatar
Car: 91 Camaro RS
Transmission: 700R-4
My car does the exact same thing but at about 2800-3000 RPM, and doesn't like to downshift to go above it. it REALLY pisses me off. (My issue cannot be caused by exhaust/intake, its carbed and has new exhaust)
The lack of fuel issue sounds like it might be something, I should hook up a pressure guage and see what mine is doin. Could it be a mis match between engine and rear gearing?
Old Apr 11, 2006 | 11:00 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
x-wolf make sure your not getting loss of spark/misfire through arcing or bad wires. One of mine was burned on a header and caused me to receive shudder/vibration around 3000rpm trying to accelerate and could not downshift out of OD.
Not a clogged cat, as I dont have one. Not a bad MAF(mass air flow meter) cause i dont think i have one, unless u mean the little baro sensor thing.
Has anyone ever had a coil start to go bad, what does it cause?
Old Apr 12, 2006 | 12:00 AM
x_wolf's Avatar
Car: 91 Camaro RS
The wires are a bit.....charrish looking but they look solid still. headers are coated, I wouldn't think theyd get damaged that bad then again....timing is off and has gottem them things red hot so I GUESS thats a possibility. I should look into that that and the fuel pressure dealio. Thanks for the idear.
cheers
Old Apr 12, 2006 | 08:26 AM
Car: 86 Z28
Engine: '90 350 TPI
Transmission: T700
i got a rough and lumpy idle and acceleration at the moment. plugs kept fowling so i replaced the leads with the plugs about 3 months ago. thought i had fixed the problem as all was fine until a couple of days ago when it became rough again. its going to the mechanic tomorrow. im thinkin its the coil but could really be anything - will post up what it is if it gets fixed.
Old Apr 23, 2006 | 09:36 PM
Car: 86 Z28
Engine: '90 350 TPI
Transmission: T700
well my car ended up throwing codes 32 and 44. replaced the o2 sensor and it seems to have helped a bit but still lumpy idle and codes are still there. havent had time to chech egr yet
Old Jun 6, 2006 | 12:37 PM
mikeburke's Avatar
I had a similiar problem. In at WOT in third gear it would hit the wall at about 3000 rpm.
I replaced the fuel filter in the carb and it fixed it.
Old Jun 7, 2006 | 01:56 AM
x_wolf's Avatar
Car: 91 Camaro RS
mine ended up being WAAAY too far advanced timing and a vacuum leak
cheers
BlueIroc-Z
Jun 9, 2019 03:22 AM
Wade787b
Sep 29, 2015 01:15 PM
MY87LT
Aug 17, 2015 08:43 AM
kyleb24
Aug 15, 2015 08:24 AM
TreDeClaw
Aug 14, 2015 06:58 PM
