New motor startup...leave EST wire connected for Timing???
Old Apr 15, 2006 | 12:42 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i just put a 383 HSR in place of the 305 TPI..i konw to adjust the timing you need to leave the EST wire discconected but since this is the first startup of this motor should i leave the wire connected then disconnect it to adjust the timing... im so lost
Old Apr 16, 2006 | 01:21 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i would leave it disconnected, fire it up, get timing right. and let it warm up, then shut it down, reconnect est, then fire back up and drive.
Old Apr 16, 2006 | 08:46 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
cool. what does that wire do anyway?
Old Apr 16, 2006 | 09:05 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Bypasses the ECM's spark advance and lets you set the base timing.
Old Apr 16, 2006 | 09:07 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
got it. thanks for the help!
BTW...Travis, are you on stealthram.com?
Old Apr 16, 2006 | 09:59 AM
Demon355's Avatar
Where is the EST wire on a bird?
Old Apr 16, 2006 | 10:05 AM
Dialed_In's Avatar
it's a single wire connector that comes out of the main trunk of the harness on the firewall right above the a/c box.
Old Apr 16, 2006 | 11:58 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
yes a lil bit..
BRoss99
Aug 10, 2025 05:08 PM
camaro11j
Sep 19, 2018 08:49 AM
Caspar
Jun 19, 2016 11:19 PM
Bull86
Aug 10, 2015 05:43 PM
