Harmonic damper removal
Old Apr 16, 2006 | 05:23 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Im trying to remove this piece, as im getting ready to dissassemble the short block.
Is there a special tool needed, cause the damper wont come off.
Old Apr 16, 2006 | 05:37 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yep - there is.
Old Apr 16, 2006 | 06:20 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
it's call a "harmonic balancer remover" can be rented at any parts store typically. don't hammer it off with a 2x4 and a hammer like i've seen done before.
Old Apr 16, 2006 | 07:10 PM
Spectre's Avatar
Engine: 3.0L/183
Great, thanks !
Old Apr 16, 2006 | 07:20 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your local Canadian Tire will lend you the tool. You pick it up at the parts counter and pay for it, and they refund the full price when you return it.
You need a different tool to re-install the balancer though, and they don't have a loaner for it. You can make one yourself easily enough though.
Old Apr 16, 2006 | 08:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
gotcha APEIRON! I rented that tool at C-tire about a week ago, it's the "harmonic balancer removal AND installation tool".
the 3 pronged puller guy gets it off, then there's a stud that goes into your crank snout, connects to a bigger stud, and you put the balancer up to it, then tighten a giant nut that helps push it on. Works well.
Old Apr 16, 2006 | 08:57 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Since this question was already answered about 4 times, I'll just add my
You'll have that thing off in about 5 minutes with the proper tool
Old Apr 17, 2006 | 01:40 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They must have changed which kit they're lending out then, it's only been something like 5 years since I had to rent one.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Magman
Sep 13, 2015 12:14 AM
Stroopwafel
Sep 11, 2015 06:38 AM
