LOOK AT WHAT I FOUND UNDER MY HOOD TODAY!
Old May 14, 2006 | 08:03 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I know it wont add any HP
[IMG][/IMG]
Old May 14, 2006 | 08:05 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
What the hell is that... a bird? or a Cat?
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
what is that?...
Old May 14, 2006 | 08:16 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I got into my car and I heard a scratching noise, I was like wtf? I popped the hood and couldn't figure out what it was; I went for a drive and came home. I shut off the engine and heard the same darn scratching noise; I think a squirrel has taken a liking to my engine bay
Old May 14, 2006 | 08:17 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Is it...alive?
Old May 14, 2006 | 08:18 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Originally Posted by ScottyRS
Is it...alive?
Dang it I hope so, I heard it scratching.
Old May 14, 2006 | 08:22 PM
Trah84Z's Avatar
Engine: 305 V8
get one of the flush kits that this guy used...
Attached Thumbnails LOOK AT WHAT I FOUND UNDER MY HOOD TODAY!-345950_109_full.jpg
Old May 14, 2006 | 08:24 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Now didn't you know when you add HP you have to give the worker a better place to sleep. .Sorry couldn't resist.All you have to do now is lure him/her out,if you haven't already.Try putting moth ***** under the hood when your car has to sit for any length of time(just don't forget to take them out before you use her).
Old May 14, 2006 | 08:26 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I remember that from April1, I actually saved that pic
I get like 5 to 10 MPG and live in the country with no garage I suppose I can have a live in my car third gen cat, but what is worse?
Last edited by 82 Iron Duke; May 14, 2006 at 08:30 PM. Reason: Automerged Doublepost
Old May 14, 2006 | 08:38 PM
coolram62's Avatar
Engine: LU5 305 CFI
I know how you feel I live in the country and my vehicles are just covered,no garage.My neighbor's cats tend to wander then I also have raccoons,opossums(but even a slow as they are I've never - but never say never - seen one under the hood of a vehicle).At least the deer don't know how to drive....I don't think.The moth ***** under the hood does work though.
Old May 14, 2006 | 08:43 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
This little sucker won't leave I have tried to humanely spray it out I guess I will see if it leaves on it's own before I pull out the big guns.
Old May 14, 2006 | 09:33 PM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
I guess when you have the iron duke in there, it leaves a lot of room for wildlife habitat under the hood.
Old May 14, 2006 | 09:56 PM
Bluejae's Avatar
Car: 1988 Formula 350
Engine: L98 350 TPI
Transmission: 700-R4
Put a bar of Irish Spring Soap under the car where the squirrel has been. It should leave soon.
Old May 15, 2006 | 01:50 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
just get out the hose and blast it's ***
Old May 15, 2006 | 02:00 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I had a bird build a nest on top of my engines air cleaner. Was gone for about a week, came back, drove around alot, popped the hood and there it was.
Old May 15, 2006 | 06:40 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
[IMG][/IMG]
I can't see a squirrel in that picture for the life of me..
+ 1 for the mothballs though. I use mothballs when I store the car for the winter.
Old May 15, 2006 | 10:07 AM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Can't you see that grey fur in the corner? Well the critter was gone this morning and hopefully won't be coming back.
No iron duke in this baby
Last edited by 82 Iron Duke; May 15, 2006 at 10:08 AM. Reason: Automerged Doublepost
Old May 15, 2006 | 10:45 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
sorry I came by this morning and took him. put in my honda. my hopes are the squirel will make the hampsters run quicker
Old May 15, 2006 | 10:55 AM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Old May 15, 2006 | 11:44 AM
Toehead's Avatar
hahah , I suppose so...
Old Jan 17, 2007 | 03:10 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
found a snake curled up on top of the pedals assembly in an 82 silverado pickup i was stripping and removing the entire dash from one day,
founf a bird nest next to the battery of an 84 caprice i had last fall,
have found squirrels and mice in many vehicles
dunno what else
it happens
good luck
Old Jan 17, 2007 | 03:18 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Snakes on the pedals?? EEK!
My grandma, back in the day, put he car in gear not knowing there was a cat standing on the drive shaft.
Appearntly it was a rather nasty mess
Old Jan 17, 2007 | 04:11 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
standing on the driveshaft??? a rather nasty mess??? am i missing something here??? wouldnt it just fall off??
Old Jan 17, 2007 | 05:01 PM
Bill/T/D/Y's Avatar
Car: 90 R/S camaro 3.1L stock,
Started my old truck one winter and damn near killed the neighbors cat.It had gotten into the fan shroud to keep out the weather.Non clutch fan and 302 .Dunno who was more startled the cat or me.I give it to the cat.Also have had mice run out from under the dash of my 64 malibu while driveing down the road,and had a pals 6 ft burmese python decide to go hide up under his dash.Thought it would take ride there instead of in the carry all he was useing.
The next concern for ya is did it eat anything off the wires in the engine bay?Every year when i store the malibu out back the squirles chew on my sparkplug wires and different wires as they chose.Usually takes me a weekend to find all the damage and repair it.Gonna have to try the mothballs this year.
Old Jan 17, 2007 | 06:24 PM
Gramps's Avatar
Car: 87 Camaro IROC
your runnin on ferrets!!. carefull tho, in the UK, there were ppl leaving cars in this parking lot and at the end of the day they would come back and it wouldnt start, the cause, cut wires. they later found out that the animals (either ferrets or similar species) are very territorial and if one would see another in the engine bay, they would eat whatever they saw to scare away the other guy. it was warm in the engine bay and by the end of the day they were gone because then engine was no longer warm.
hey bill my neightbour had a cat that was old, and he was workin on the car one day and the cat got ontop of the engine to stay warm. when he started the truck up tho the cat went thru the serpentine belt system, he was only given a few days to live. so they went on vacation and came back to expect a dead cat, well he had fully recovered and aside from some bald patches he was alright.
Old Jan 17, 2007 | 06:34 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
das a scary picture
Old Jan 18, 2007 | 04:55 AM
Pat Hall's Avatar
There's a pretty big space inside the fender up by the battery in my 69 Camaro. My mother's cat climbed up in there one night. I fired up the car and went to school for the day and didn't notice anything strange. When school got out, I fired up the car and started to head for home. Keep in mind, this car has about 400 HP and a 4 speed Muncie in it. Being the typical teenager I was back then, I started romping on it and making the front end come way up, and all of a sudden I heard this really strange squeaking noise coming from the engine compartment. I was like huh, I guess I better pop the hood when I get home so I can see what's making such a weird noise. Once I got home and popped the hood, you never seen a more terrorized cat in your whole life! Poor thing was shaking uncontrollably. I couldn't believe it just stayed up in there the whole time I was at school. Needless to say, that cat never came near my Camaro ever again, and I never told my mother what happened to her poor cat either! Lol.
Old Jan 18, 2007 | 12:55 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
I had mice in the 88 IROC I had, every time I heard them screech I would yell out "YOUR GONNA DIE!!!!" That was when I first drove it home from the field it was in. Opened the hatch and let the cats go to work. Needless to say, no mice after that.
Old Jan 18, 2007 | 10:35 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Wow...
Sure makes me glad I live in the 'burbs.
Old Jan 19, 2007 | 09:08 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Stopped at macdonalds for a quick bite one nite. Was sitting in my car, chowin' down, and this truck parked next to me, and the driver got out, opened the hood, and started looking around with a puzzled expression. Got out to see if I could help, and he stated his truck was making some really odd noises.... Turned out, a cat had made a home in the front fender......
Old Apr 21, 2007 | 04:57 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Re: LOOK AT WHAT I FOUND UNDER MY HOOD TODAY!
Back when we were lifting 5 ton trucks onto the boat, we noticed a cat on one of the axles, so yeah we had to lower the truck back down to the pier, and get the cat off from there.
I think the kitty wanted to get here the free way, no boat ticket, no visa *L*
Street Lethal
Apr 30, 2019 12:14 PM
spaigo
Aug 21, 2015 07:46 PM
bjpotter
Aug 12, 2015 06:06 PM
Bradsaundry
Aug 12, 2015 12:34 AM
antares57
Aug 6, 2015 07:47 AM
