Throw away a 383ci SC for a gen 3 v8???
Old May 21, 2006 | 07:48 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Hey how many of you guys think swapping out a built 383 with a ati procharger for a built ls2 and a six speed? I figure it's 2006. out with the old and in with the new. Am i nuts?? I was gonna get most the running gear from a z28 and building a ls2 block. Thanks
Old May 21, 2006 | 08:06 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
make sure you toss that 383 hard enough to land in my yard
Old May 21, 2006 | 08:18 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
Old May 21, 2006 | 09:26 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
If you can't toss it all the way to Canada, my yard's closer.
Man if I had the money to drop an LS2 in my car I would do it in a heartbeat.
Old May 21, 2006 | 10:48 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have been toying with the idea of swapping out the 383 in the Formy for an LS motor.
Old May 22, 2006 | 12:19 AM
EvilCartman's Avatar
Car: '82 Z28
I'm closest so it should land here or I can pick it up within 12 hours, 10 if I really put my foot into it
Old May 22, 2006 | 08:50 PM
blizzard's Avatar
Car: 86 T/A
Engine: 383 stroker N/A
Transmission: th350
Axle/Gears: 4:11
i have a 383 in mine and wouldn't trade it for nothing!!
Old May 22, 2006 | 09:03 PM
ap72's Avatar
Really the biggest and only main advantage the LS engine series has over the original SBC's is the head design. Save the money and invest it in a good aftermarket 18* head setup and make way more power.
Old May 22, 2006 | 09:38 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
toss the 383 and the procharger?? the only LS series motor that could make me sit up in my seat with my 383 procharger combo is the LS7...and you won't be seeing that all over the place swap with the LS7 for while.
Old May 22, 2006 | 09:57 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
If you're making WAY more power in the LS2, then sure. But I'm welling to bet you wouldn't make much more, especially with that blower.
The LSx series are great motors, but not all powerful. Cubic inches are still the master of potential - the LS2 is only a 6L motor, your 383 has a few more cubes.. plus it's blown.
Cliff's Notes:
Are you dumb?
Old May 22, 2006 | 10:12 PM
I have 5 payments left on my tacoma ('03) and soon as i'm done with that, a427 with a BIG innovative turbo setup will come to life. Will probably end up selling the 383/procharger in the car now to help fund that build up....shooting for mid season next year.
Old May 24, 2006 | 04:21 AM
IROZINCO's Avatar
383 and procharger
Hey - Colorado and Arizona are close! Land that one in MY yard!! I've got a bone stock 87 350TPI and as soon as it quits running I want a 383!
Old May 24, 2006 | 07:47 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I still plan on turboing my 383 in my Formula its a conventional vortec headed 383 small block.
After my friend and I did an LS1 conversion in his GTA, I personally think I would be an idiot to build another conventional small block when I can do a swap easy and quickly enough, let alone prices are falling on the GEN III stuff.
Would I yank it if it was all good, prolly not.
Would I go to an LS? if it was junk? Almost certainly.
Everything has its day, the LS series engines trump ours in every way with the exception of cost and the more they make, the cheaper it gets.
later
Jeremy
Old May 24, 2006 | 12:12 PM
Transmission: 4L80E
383 for LS motor
Haha you guys crack me up. Well i am gonna keep the motor just in case (you know how that goes). The cars a 25th anv z28 and i dunno if i'm stupid for putting a diffrent motor in it. The reasoning is i've had nothing but problems with overheating and snapped cranks. Overheating- trickflow heads, new water pump (several times) be cool radiator. dual fans wired on all the time, several combos of thermostats, air dam intacked, i'm thinking the intercooler is stealing all the air though. Sit sideways with a big scoop in front of air dam. Any suggestions??
Old May 24, 2006 | 06:05 PM
Mark 89Formula's Avatar
The ATI intercooler definetly is adding to your woes. Willie figured out how to run 2 of the small front mount intercoolers in place of the stock radiator blocker that ATI supplies. His setup worked just as well as the big single from a charge cooling standpoint and greatly reduced coolant operating temp. An ATI vendor is selling the kit he designed. Search a bit on the Power Adder board and you should be able to get some info. Highly recommended for a Procharged car in warm climates.
Terrell351
Jun 13, 2021 01:13 PM
Infested
May 22, 2018 11:56 PM
lt1z350
Sep 29, 2015 01:50 PM
ydnar417
Sep 23, 2015 05:57 AM
rsrmoore
Aug 7, 2015 08:44 PM
