is it possible to convert press-in wrist pins
Old May 23, 2006 | 04:17 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
into floating? I want to use these SpeedPro forged pistons but I don't have a rod furnace and don't want to half-*** it in a conventional oven.
Old May 23, 2006 | 05:13 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
haha, "rod furnace"?? half *** it, and use a normal oven? I've never even heard of a rod furnace... These aren't rocket surgery here. Toss your pins in your freezer, put your rods in your oven, lube the pins with clevite bearing guard (jam), and use gloves, push them together. Or get your machinist to do it for you. It's easy as pie.
No, I don't think you can convert, or it'd be not worth the hassle if you could.
Old May 23, 2006 | 05:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If those pistons have the provisions to take the locks, then it would be the size of the small end of your rods that would make it a press fit or not.
Old May 23, 2006 | 05:35 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I haven't purchased the rods yet. Can I get floating wrist pins and use them in any old piston? IE they're the same size as "press fit" pins?
Old May 23, 2006 | 05:51 PM
ede's Avatar
ede
the pistons need to be made for the retainers used with floating pins and will also work with pressed pins. the small end of the rod is what makes it pressed or floating. if your rod doesn't have a bushing your machine shop can put one in for you to use floating pins. if you have pistons made for floating pins you can use them with a pressed fit rod and have pressed pins with no extra work or expense, just leave the retainers out with the pressed pins. don't try to force pressed pins in or out without the proper tools and equipment.
Old May 23, 2006 | 05:56 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I have these SpeedPro pistons, and I dont think they offered them in floating. So they wouldn't work even if I had bushed rods, since there's no room for a retainer clip.
Old May 23, 2006 | 06:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
I wouldn't sweat it, bushed probably isn't for you, you aren't planning on tearing down the motor annually are you?
vizard mentioned pressing them in at home using the method I mentioned, but I got my machinist to do it for me.
Old May 23, 2006 | 06:28 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
sorry but that cracked me up
Old May 23, 2006 | 06:50 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
No it's not a big deal, but I wanted to be able to assemble them easilly right away.
I don't want to pay a machinist to do something as stupid as hang slugs, ya know?
Old May 23, 2006 | 07:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Vizard seems to say a lot of things that make a lot of people scratch their heads. I know people who have met him through the Mini racing crowd, and I've heard some interesting opinions.
The cost to press the pistons on is pretty minimal, usually on the order of a few dollars each.
Old May 23, 2006 | 08:20 PM
Vader's Avatar
And the cost to cut a lock ring groove at any competent machine shop is also negligible. Any mini boring head (like a System 3R) and square insert would make it cake - Just plain old boring work. Gundrilling the rod for pin oiling, boring, honing, pressing the bushing, and finish reaming it would be costly compared to a set of rods prepped for floaters and oil.
wigmobile
Feb 26, 2025 02:56 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Sep 16, 2015 12:37 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
