car dies with vac.advance hooked up
Car: 91 firebird
Engine: 350 vortec heads
Transmission: t5
Axle/Gears: 3.08 open diff
350 carbed 91 firebird.with vac advance connected to timed vacume port car dies when i rev it.disconnect the vac advance and the car dosent die.new diaphram.whats goin on?
Car: 91 firebird
Transmission: t5
is it possible that the engine is pulling way too much vaccum and whenever i hit the throttle its advancing it way too much.isnt there a way to adjust the manifold vaccum.
No, not possible.
Check to make sure your rotor tip isn't bent over to the side.
If you're using "ported" or "timed" vacuum, there shouldn't be vacuum there at idle anyway.
Car: 91 firebird
Transmission: t5
well i have a junk distributor my buddy made up with spare parts.i geuss my best bet is to get a new distributor.hey is it possible to burn almost a quarter tank of gas just idiling for 30 minutes with a poorly tuned carb.its an edelbrock 1407 750 out of box.im running 350 bored 60 over vortec heads mid cam 9.5 compression.or do i have other problems,or am i just experienceing the crappy gas mileage im going to get with this setup
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
its definately got to be running rich.
When i did the break in on my motor, 30min @ 2500rpm i burnt about 1/8 tank.
BTW Edelbrock carbs arent good for anything but looks! check out the numerous threads about them on the carbs board.
db057
Aug 11, 2015 10:11 PM
