help with heads and cam choices..!!!
Old Jun 1, 2006 | 10:45 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
can someone refer me to webistes or books for basic knowledge about heads and cams??? im trying to get a better understand of each so i can buy the correct parts. ex. what is lift, lobe, duration??? 54cc, 72cc, etc .... like what do all these terms mean and purpose... thanks,
Old Jun 1, 2006 | 10:51 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Lift = how much the cam is going to move the valve, this is limited by the height of the valve guide on the head. usually stay around .45 or less for stock heads.
lobe = the oblonged shaped part of a camshaft
duration = the timing in relation to the crankshaft in which the exhaust and intake valves will open/close
Head chamber CC'c = exactly that, the volume of the heads chamber measured in CC's. To select the right sized chamber you will have to calculate your compression ratio in which you will need to know piston specs and a few other goodies.
Hope that clears up a few things for you.
Edit: You can find a compression ratio calculator here : http://www.csgnetwork.com/compcalc.html
If you want, when i get home i can send you this neat little calculator program that will tell you your static and dynamic CR.
Old Jun 1, 2006 | 12:01 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
send it to: wnickles@tmail.com
thanks
Old Jun 1, 2006 | 12:05 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
thanks
Will do!
i might get a chance to send it at lunch time if not i will do it after work!
Old Jun 1, 2006 | 09:42 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
anyone else with any info???
Old Jun 1, 2006 | 10:32 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Sorry it took so long, i just sent you that wicked calculator program
Old Jun 2, 2006 | 09:36 AM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
I am looking at the same thing. do you think you could send me that program too by any chance?
Old Jun 2, 2006 | 12:50 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Think I could get a copy as well? If ya can mine is darkstar096@yahoo.com Thanks.
Old Jun 2, 2006 | 07:36 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
83sc, whats your e-mail?
Res- Just sent you the copy.
Edit: Ok here, ill make things easier...
Web link to the DCR calculator http://cochise.uia.net/pkelley2/dcrvb6.zip
Old Jun 3, 2006 | 11:11 AM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Calculator
If possible, I would like to get a copy also. You can send it to wildjyoung@gmail.com.
Thanks!
Old Jun 3, 2006 | 01:01 PM
1983sc's Avatar
Car: 00' rcsb
Transmission: 4l80e
well poo, sorry about that my email is iamthecoolest_3@hotmail.com
thanks
Colt
Old Jun 3, 2006 | 10:53 PM
BadSS's Avatar
Here's a good cam info link
Cam Science
These articles are on Mopar heads, but the general principles apply to all - and it's about as good as free info gets.
Cylinder Heads, Part I
Cylinder Heads, Part II
Cylinder Heads, Part III
Old Jun 3, 2006 | 11:13 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You can buy a very good book on all this from many Speed shops or online from Amazon.com: Online Shopping for Electronics, Apparel, Computers, Books, DVDs & more
The author is David Vizard. The book is called "How to build Max Performance Chevy Small Blocks on a Budget!" Best $10 you'll spend on the subject.
You can also find much of what you're after in your local Public Library.
Search the "Subject" and the "Title" card catalog(s) for Hot Rod, Hot Rodding, Internal Combustion Engine(s) "High Speed Internal Combustion Engine(s)"
You can also google " camshaft lift", "duration", "duration @ .050" "lobe separation" "Overlap". Compression ratio, among other search terms. Just remember that the N-E-T stands for "not entirely true".
84z96L31vortec
Aug 20, 2017 12:16 AM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
