help with removing left valve cover
Old Jun 4, 2006 | 09:52 AM
firechickenred's Avatar
I am trying to remove the left valve cover and there is like a filter in the way that wont let me pull it out. I removed everything but that and I still can't do it. Can someone tell me how they did theirs. My car is a 1992 Firebird. Thanks!
Old Jun 4, 2006 | 12:19 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
That looks like the A.I.R. system check valve.
I cut my A.I.R. out.
Old Jun 5, 2006 | 11:48 AM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
That is threaded onto the exhaust manifold. It should be either a 1" or 1 1/8" wrench. Spray the threads with lots of WD-40 before you try to remove it.
Old Jun 5, 2006 | 01:43 PM
yeah man I will try to take that off. It seems that is the only way to take the valve off. Thanks
Old Jun 20, 2006 | 01:43 AM
WSM027's Avatar
Car: 1986 Trans Am
Engine: 350TPI
Axle/Gears: Factory..for now
It's the only way I know how to do it. PB worked a little better for me than WD-40 did though.
Old Jun 20, 2006 | 06:15 AM
Support the tubing with another wrench while you reef on the check valve; otherwise you'll just end up trashing the whole thing. You'll find that once it breaks loose, it will come right off. Put a wrap or 2 of Teflon tape on the threads to keep it from being such a PITA in the future.
Old Jun 20, 2006 | 10:08 PM
puffcat's Avatar
Car: 1988 Iroc-Z
Engine: 305 v8 tpi
Transmission: manual
Axle/Gears: posi
There's prolly 2 of those in your way yah? Just do as the other guy said, use 2 adjustable wrenches on either side, you'll prolly also have to actually bend those things to get the valve cover back in. Also, is your heater core valve above that cover, if so you no doubt gotta remove that, before you do drain coolant below the thermostat or you'll have coolant go into your motor like I did. You can also go on and take off that filter thing, the base should have only 2 screws that attach it to the AIR pump. I think there's a gasket too but I don't think mine survived and I don't have one on.
Old Jun 21, 2006 | 09:40 AM
I was finally able to remove the cover by taking those off. Thanks a lot for the help guys.
Cameeeero
Sep 18, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
