Removing Coolant Resevoir
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Quick question:
Doing my top end rebuild and cleaning up the engine bay soon, can I remove the coolant resevoir and just run a hose to the ground like in older Chevys, or will missing a coolant resevoir be hazardous to my motor in terms of overheating?
_Clark
_Clark
Car: 1992 Camaro RS
Axle/Gears: Stock
Originally Posted by GuitarJunki17
Quick question:
_Clark
_Clark
Originally Posted by ScottyRS
I'm not too sure what you mean by running a hose to the ground, but some people on this site have found smaller over flow tanks and placed them under that front plastic piece under the hood. Or you can buy one from Summit. Either way I recommend you keep it.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Some other alternatives are 1) a smaller stock tank - I installed the smaller one and I like it, or 2) an aftermarket tank - they make all different shapes, sizes, colors, styles, etc. Just about anything will work - I once saw a Bud can used as an overflow.
My car does on occasion get hot. The overflow tank not only serves as a place for the expanding hot liquid to drain to other than the ground, but it also serves as a method of maintaining coolant levels. You get hot, coolant expands, flows out - no tank to flow to, you lose it. Car cools, coolant is sucked from tank back into system - no tank, no replacement coolant. Tomorrow, you get hotter, since now your coolant level is low. Are you willing to wait until it cools, and check the level daily?
I know - no tanks on older cars - however, also remember that in the old days, gas stations pumped the gas (full service), not just sold it (self service) - they always popped the hood and checked these things for everyone on every fill up. The driver had no need to always check fluids - it was always done for them. Also, no one was ever stuck in "5 o'clock traffic" for hours on end, with A/C running (there wasn't any), and 14 million cars side by side heating the highway with exhaust. I'd keep some kinda tank, unless it's a track car - even on your Sunday country cruise you may wind up in a 20 minute idling, overheating delay.
Earlier systems without overflow tanks were designed to run with about 1" of air at the top of the rad when cold. There is no reason you can't do that on a 3rd gen- it won't affect cooling hardly at all. However, if you get a coolant leak there will be no way to know it without taking off the rad cap and see of the coolant level had dropped at all since the last time you checked. External overflow tanks are easy reference if you have a coolant leak- you'll see the level getting lower in the (see-thru) overflow tank day by day.
Cool, thank you guys for your input. I'll probably go with a smaller aftermarket tank then. CamaroNewbie, you said you had one, do you have any pics of it under the hood? Thanks
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
side note; my local race track requires an overflow tank to be allowed to race. No idea why. Anyway, just something to keep in mind.
Englishtown (Raceway Park) is more strict, so that is a good point. They actually make you lift your hood.
Car: 1992 RS
Engine: Carbed 350
Sorry - no pics - no digital cam at the moment. Just hunt the boneyards for a 3rd gen with a smaller tank - it looks the same, just smaller.
FormulasOnly
Sep 10, 2015 09:07 PM
