how do you test vacuum pressure?
Old Jun 20, 2006 | 08:58 PM
Italiantank48's Avatar
Car: 1988 Chevrolet Camaro
Engine: 2.8 v6
how do you check your vacuum line system's pressure? I think it should be pulling 12-14 psi at idle, but how do i find out if it is?
Old Jun 20, 2006 | 09:06 PM
G-Ride14's Avatar
Car: 1988 GTA
Transmission: 700-R4
Axle/Gears: 9-Bolt 3.27
Use a vacuum gauge and hook it up to a vacuum line off your plenum. I pulled over 18in/Hg off mine.
Old Jun 20, 2006 | 09:27 PM
Engine: 2.8 v6
easy enough I guess... 18psi is better it seems, after a bit of research 20+ psi means your car is running optimal... gotta find a vacuum gauge... but since it's about the same price to get a car/dash mountable one and a handheld one, I might as well get the mount one?
Old Jun 20, 2006 | 09:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Manifold vacuum is normally measured in inches of mercury, not psi.
Old Jun 20, 2006 | 09:31 PM
Engine: 2.8 v6
getting more and more confused...
Old Jun 20, 2006 | 09:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Your vacuum gauge will show vacuum in inHg, not psi.
20 or so inHg at idle is fairly normal with a wimpy stock cam. The larger the cam, the lower the vacuum reading.
Old Jun 20, 2006 | 10:25 PM
G-Ride14's Avatar
Car: 1988 GTA
yea i meant to put in/Hg
Old Jun 20, 2006 | 10:28 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
yikes i do have low vacuum, i shoot for 9Hg at idle....
Old Jun 21, 2006 | 10:35 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
My 305 would only make 4-6 in/hg at 750 RPM in Drive with the A/C on. I still had brakes thanks to Hydroboost and A/C due to a vacuum canister.
Old Jun 23, 2006 | 01:09 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
i have ta idle at 1100rpm for 9in/hg, anything less and not having a can or pump can kill...
Bubbajones_ya
Aug 28, 2015 02:17 AM
mike_c
Aug 27, 2015 04:32 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
