Felpro or GM Head Gasket
Old Jun 23, 2006 | 03:11 PM
steve88iroc's Avatar
Car: 1988 IROC-Z
Transmission: WC T5
Hey guys,
I need some input on which head gaskets to purchase for my impending vortec swap. Stock replacement from GM PN 10105117 .028 compressed thickness, or Felpro 7733PT-2 .039 compressed thickness.
How much of a difference in compression will you see from a .011 difference is compressed gasket thickness?
Steve
Old Jun 23, 2006 | 03:13 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
up to .5 of a point depending on the motor.
Old Jun 23, 2006 | 04:35 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
if you're using those gigantic combustion chambers in those Vortec heads anyway... well I don't know what to tell you.
Old Jun 23, 2006 | 05:53 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Forget Felpro...use the GM you won't regret it.
Old Jun 23, 2006 | 05:56 PM
mw66nova's Avatar
Engine: 7.0L
gigantic? they are 64cc, which is what the 083 heads were.
Old Jun 24, 2006 | 08:32 AM
Car: 1988 IROC-Z
Transmission: WC T5
Like Nova said, the combustion chamber size is 64cc, same as the heads that are on the car now. Thanks for all of the input guys.....looks like I'll pick up the GM gaskets.
Steve
Old Jun 24, 2006 | 09:11 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
ive used the felpro blues not sure if i like them because My last engine may have had a bas gasket but supposively you dont have to retorque
Old Jun 24, 2006 | 09:24 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ive only been using the Corteco gaskets for the last year. Very good product IMO.
Old Jun 24, 2006 | 10:20 AM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Save yourself some potential problems and just use the GM .028 head gasket. The price is right and is of excellant quality.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
