car stalls when braking hard
Old Jun 27, 2006 | 02:13 AM
ztweny8's Avatar
Car: 82 Z28
Engine: SBC 350
Transmission: 700R4 w/Shift kit
Hey, my 82 Camaro seems to wanna die when I brake hard, and if I slam on the breaks n come to a dead stop or near a stop, it does die. What could this be related to?
Old Jun 27, 2006 | 07:06 AM
fawien's Avatar
right off the bat two things that come to mind. Vacuum problems or the carb is losing fuel when the motor slams to a stop.
Its possible the fuel is sloshing around in the carb and not getting picked up to go to the jets when you come to a violent stop.
That or when you need that strong break power the brakes use vacuum off your manifold for the power brake unit and you may have a vacuum leak somewhere.
Old Jun 27, 2006 | 10:38 AM
ztweny8's Avatar
Car: 82 Z28
Engine: SBC 350
if their was a vacum problem, would it also make the car run a little rough? I find that if im cruisin along at 60km/h and I let of the gas a bit, to were im just a bit under maintaining 60, it starts to sputter and stuff. Could that be connected? Its like you always have to go about half throttle or it will hesitate n sputter. Its a new Holley 670 avenger carb, so that shouldnt be the problem.
Old Jun 27, 2006 | 10:43 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Also another thing. Does your 82 have overdrive with a locking convertor? If so, it could be sticking locked, which will stall the car once you stop.
Old Jun 27, 2006 | 11:44 AM
Neil87Z28's Avatar
Car: 1987 IROC Z28
Engine: 427ci
Transmission: TH350
Check your carb float level. They are most likely adjusted too low.
Old Jun 27, 2006 | 02:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I also think you have a vacuum leak, probably near your brake booster.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
