4 bolt main???
Old Jul 16, 2006 | 09:14 PM
85T/A's Avatar
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
4 bolt main???
is there a way from the casting numbers on the front of a block to tell if its a four bolt main
Old Jul 16, 2006 | 09:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, the same castings were used to make 2 bolt and 4 bolt blocks. Only the finishing machining was different.
If it's a 305, there's almost no chance that it's a 4 bolt block.
Old Jul 16, 2006 | 09:37 PM
85T/A's Avatar
no i bought a 350 yesterday i know my305 isnt one
Old Jul 16, 2006 | 09:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
For pretty much anything streetable, it isn't going to make a difference to you whether it's 2 bolt or 4 bolt. If you've got the engine already, then there are only a few oil pan bolts keeping you from finding out either way.
Old Jul 16, 2006 | 09:54 PM
85T/A's Avatar
true i didnt think of that but i cant do it its sitting on a crate and i dont have a stand
Old Jul 16, 2006 | 11:12 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
well depends on year.
the 305 outta my truck was a 4 bolt. 83 GMC K1500
Old Jul 16, 2006 | 11:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, 4 bolt 305s do exist, mostly in Canadian pickups. Not especially common, though.
Old Jul 16, 2006 | 11:28 PM
85T/A's Avatar
well my 305 was an 85 lg4
Old Jul 17, 2006 | 05:38 PM
punishr's Avatar
Car: 06 silverado, 85 camaro
Engine: in the works
interesting...ive always been told they didnt come from the the factory as 4 bolts, you had to splay it out.
iono why everyone desires a 4 bolt over a 2 bolt, especially in a street car. how many motors have you personally seen that have **** themselves because you didnt have a 4 bolt main cap...granted im only 19 but ive been around engines my whole life, my dads built them for 30 years and my grandad (first person to get the SBC to break 10,000 rpms in the outlaw sprint series) has NEVER seen one fail because of this, just fail because of dumbass builders..
but to answer the question, if you look the casting number up most likely you will get "some were 4 bolt, some were 2" im with Apeiron just pull of the oil pan...
Old Jul 17, 2006 | 11:45 PM
TheLG4Whore's Avatar
Car: '86 Trans Am
Transmission: TH700R-4
Axle/Gears: 10 bolt 3.73
to be honest with you a 2-bolt 350 can handle 400+hp anyway. it'll handle anything you will most likely throw at it.
Old Jul 18, 2006 | 04:50 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
id like to know the casting number off the block of this supposed 4 bolt 305
the stamping cod eis whats on the front pad of the blocks btw
alot of the times the listing will say if its 4 bolt or not by the stamping code
good luck
Old Jul 18, 2006 | 05:56 PM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
I have heard of 4-bolt 305s in trucks before, though I have never seen one.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
fasteddi
Sep 10, 2015 09:32 AM
angel2794
Sep 8, 2015 06:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
