oil pan
Old Jul 17, 2006 | 05:55 PM
85irocz28's Avatar
Car: 1985 Iroc Z
Engine: 383 carbed
Transmission: Th 400 tci super street
Axle/Gears: 3:42 9 Bolt
oil pan
heyguys im having a hard time findin a oil pan for my 2pc 383 with a dip stick on the right side. it needs to be cheap too can anyone steer me too where wat im looking for
Old Jul 17, 2006 | 10:28 PM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
Transmission: Built 700r4
yep....
are you still wondering why?
passenger side dipstick 2pc rear main seal oil pans do not exist buddy boi!
Old Jul 17, 2006 | 10:56 PM
85irocz28's Avatar
Car: 1985 Iroc Z
Engine: 383 carbed
well i guess my engine builder must be a retard then... uhh
Old Jul 18, 2006 | 11:32 AM
12SecondTA's Avatar
Car: 85' TA
Engine: 355 Carbed
if he told you to get a passenger side dipstick 2pc rear main seal oil pan, then i'm sorry, but yes, he is...
its just how things are....
Old Jul 18, 2006 | 12:13 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I better put mine on ebay QUICK! cuz it sounds like it's worth about 2 million bucks. Good thing I have a few of them huh?
85irocZ28: this SHOULD work but you might have exhaust clearance issues
Moroso Street/Strip Oil Pans: MOR-20165 - summitracing.com
There are others, but the max stroke is 3.480"..
-- Joe
Old Jul 18, 2006 | 12:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That's right. All those millions and millions of small blocks built between 1979 and 1985 that seem to have passenger side dipsticks are just illusions produced in the mind as a result of a joint project between GM and the CIA to develop and deploy mind control satellites. It is often conjectured that the same system was used again in later mass-hypnosis projects, as it is the only means to explain the popularity of reality television, pop music and certain types of cheese.
Old Jul 18, 2006 | 12:42 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally Posted by Apeiron
That's right. All those millions and millions of small blocks built between 1979 and 1985 that seem to have passenger side dipsticks are just illusions produced in the mind as a result of a joint project between GM and the CIA to develop and deploy mind control satellites. It is often conjectured that the same system was used again in later mass-hypnosis projects, as it is the only means to explane the popularity of reality television, pop music and certain types of cheese.
Oh no, what have we uncovered here. wait.. who is that knocking at my door...
-- Joe
Old Jul 18, 2006 | 12:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's just how things are, you know. . .
BDR
Nov 7, 2015 03:05 PM
project89
Sep 22, 2015 09:35 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
