How much for a starter?
Old Jul 18, 2006 | 12:48 PM
mofolife's Avatar
Hi, I took my car to the shop because it was having trouble starting. They told me a starter would cost 300 dollars. I have a 1994 Z28 Camaro. Cant I find a starter somewhere for $100 or less?
Old Jul 18, 2006 | 12:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Well, a 1994 Camaro would be a 4th generation model, not 3rd.
You might try asking on LS1LT1.com - Powered by vBulletin , or looking it up on www.partsamerica.com .
Old Jul 18, 2006 | 01:06 PM
MAD_IROC-Z_85's Avatar
Car: '85 Iroc-Z
Engine: 355cu, 11:1, 292H, 750cfm, LT1 head
Transmission: T5 non/wc
Axle/Gears: 3.73, 7.5in 10bolt posi
Go to a Car-Electrique shop, you can rebuild you'r one for less than 100$
YOu will have a new one!!
Old Jul 18, 2006 | 03:30 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Wow, I'd really hope you can get one for cheaper, seeing as ACDelco starters for 3rd gens only cost 15$
Just go to autozone.com and check to see how much it'd run you.
Old Jul 18, 2006 | 05:09 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
300$ installed? or 300$ for the starter itself?
if its 300 for the starter itself,
i think ur getting ripped off.
i bought brand new starter(WITH solenoid)
for 140bux.
ofcourse thats for a 3rd gen but shouldnt be much of a difference
in price caz its still a same car,
ur not comparing a honda with a jaguar
so shouldnt be that much difference in price.
try local auto store, they usually have it.
Old Jul 18, 2006 | 06:50 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
A brand new LT1 starter is 180.00 at Advance auto. Alldata shows 1.4 hours to replace. At 75.00 an hour your right in your quote after tax and such.
Old Jul 18, 2006 | 06:56 PM
Raiderfan's Avatar
Car: '92
Not thirdgen related(i'm interested though), but i'm surprised at the cost of the starter and 1.4 hrs to replace.
Please fill me in on the labor and cost for the starter.
Old Jul 18, 2006 | 06:59 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Thirdgen starters and Fourthgen LT1 starters are different. The LT1 starter is a gear reduction type.
Old Jul 18, 2006 | 07:05 PM
Raiderfan's Avatar
Car: '92
Thanks for the response, do you know why it takes so long to replace.>?
Old Jul 18, 2006 | 07:46 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
No. Thats just what it calls for.
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That's just the black book time allotment for it. They say 6 hours to do a timing chain I think... Must be lazy mechanics
But yea, a $15 starter is a pipe dream. $150 or so is about right. Labor to have some joker do it for you, yea, $300 is pretty normal.
Old Jul 18, 2006 | 07:58 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Easy now. Thats how I make a living.
Old Jul 18, 2006 | 11:18 PM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
Can you use a fourth gen starter on a third gen? I was going to swap one because the 4th gen is smaller and hopefully will not get heat soak...
POZ
(not trying to hijack...)
Old Jul 19, 2006 | 12:02 AM
EvilCartman's Avatar
Car: '82 Z28
I'm using a Hitachi starter, quite small and direct drive with 160 ft lbs of torque. Gained probably an inch of space between the header and starter body. Was using a napa brand gear reduction starter, had too many problems with them not working right. This new one is nice, comes with it's own starter bolts and can be clocked very easy. I'll see if I can get a part number tomorrow if you're interested.
Old Jul 19, 2006 | 12:59 AM
I hope you are talking about the ones for 4th gens, cause autozone stocks them for third gens for 15$ when you trade yours in. Sure it's a heavy Delco one that will probably crap out in a few years but it has a lifetime warrantee, and it gets the job done.
Old Jul 19, 2006 | 01:01 AM
Sonix's Avatar
Car: 1982 Trans-Am
Well chalk that up to another american dream then. If I called up my local autoparts stores (in canada), I can guarantee you I couldn't walk in and out with a new starter in hand, for under a $100. For my '82 Trans-am, standard, run of the mill SBC.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
