Over 10 on 1 Cylinder?!
Old Aug 5, 2006 | 06:50 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
So I have a 350 sitting waiting to go into my camaro... The problem is that when i had themachine work redone the machinist told me one cylinder was too rusted to just hone so he suggested boring the 1 cylinder over 10. I said no that rediculous do them all or do none but my father insisted on letting him do it.
What I am want to know is, is this engine a big paper weight now?
Can the engine be balanced with 1 cylinder 10 over?
And if its alright to drive like that would beating on it make a difference?
Old Aug 5, 2006 | 08:26 PM
r0nin89's Avatar
Noone? I thought this would be a simple "theres no problem with that" or "thats ****ed up" question.
Old Aug 5, 2006 | 08:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It could be done, but it's not the right way to do it.
Old Aug 5, 2006 | 08:43 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
That is a common practice on 2-cycle outboard boat motors (that melt pistons every once in a while) but I've never heard of doing it on a car engine.
I would think that it will be fine, just kind of a strange approach. Are you re-using 7 of the old pistons? If so, then ok, you maybe saved a few bucks on parts. Still it sounds kind of back-woods to me.
Old Aug 5, 2006 | 09:11 PM
r0nin89's Avatar
Yeah I think its really stupid and just off... If one cylinder is .040 over I think I might just have him do the other 7.
Old Aug 5, 2006 | 09:27 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
it should be fine with one cylinder .010 over the rest. Are you planning on balancing the motor? Race type motor or street? how much you putting into the motor total? $? I think you'll be ok, unless you're doing a high buck race motor, then you want it all the same...
Old Aug 6, 2006 | 12:33 AM
Vader's Avatar
I've torn down high-mile engines that have had ONE +.010 piston, or less than a full complement. That's a cheap and dirty way to repair an engine, but it works. If balance is not much of a consideration, or even if it is, it can be done. For the cost of a full set of pistons, and the minimal cost savings of boring only one cylinder, it may not be worth it.
Old Aug 6, 2006 | 11:08 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
I totally agree with vader. I was always wondered if that could be done (never did it though), but I was afraid of balance issues. The way I looked at it, you have one cylinder that's SLIGHTLY more displacement than the rest, and I was always worried about putting more load on just one area of the crankshaft.
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
