Trans Am H.O. Engine ????
Car: 89 Iroc - 84 Trans Am -84 Corvette
Engine: 350 TunedPort
Transmission: 700R/T-5 World Class
Axle/Gears: Posi/Ausi/Disc/3.08
I have a question about the so called H.O. Hight Output engine. Was this engine actually a different version of the regular engine or was it just some type of clever marketing by G.M. back in the 80's to sell more vehicles????
I simply can't see how an '84 Trans am with a so called High Output engine rated at say 185 H.P. was considered to be High Output ,,,Hello my V6 Saturn Vue has about that. Can anyone shed some light on this topic I'd really like to know if there was a difference. I know that many may have no idea but I hope someone can really give me an honest answer on this. Thankyou.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
yes, it's slightly different then the "normal" 305. The normal one put out about 150HP.. Sad eh? That's the "low output" version.
the high output version has:
dual snorkle air intake
bigger chamber exhaust manifolds
slightly more aggressive camshaft
maybe different exhaust piping (?)
Car: 1983 G20 Chevy
Transmission: 4L60
Flattop piston with 4 valve reliefs vs dished
Corvette style monolithic converter
Different secondary metering rods and hanger
Revised prom chip with a hotter timing advance table
Higher stall torque converter (automatics)
3.73 gears (typically)
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Its all relative... 190hp is higher than 150hp, so there is now an "HO" motor and a "LO" motor.
Car: 1982 Trans-Am
uhh yea, kinda hard to compare it to future vehicles, I don't think they could read the future...
At the time, the 4cyl camaro had 92 HP I think, 112HP for the V5 I think, 150HP for the LG4, and up to 190HP for the L69 "5.0L HO". The 350 around '75-'85 was also around 170HP, so a 190HP 305 was pretty good.
Add to that list a few things
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Once again, look at when the car came out. At the time, it could beat up just about any other new car on the market. As sad as it is, it was pretty much the most power they could make with the technology of the day while meeting emissions standards.
Car: 1983 G20 Chevy
Transmission: 4L60
Yeah, but you are still talking about the early 80s with emissions a real consideration then. Todays technology really opens up the potential for alot higher HP numbers. The only thing is that the torque from the newer engines still has not been substantially increased. What that amounts too is an engine that is gutless at low engine speeds but makes good HP @ high rpm. The 305 makes plenty of low speed torque for what it is which is good.
I will take a torquey 180 HP engine over a peaky high reving one anyday.
My 180 HP 1983 305 HO pulled my 5,200 lbs G-van around just fine for nearly 200,000 miles
Car: 1982 Trans-Am
yea, driving 200HP hondas with 120ftlbs of torque is just plain annoying, compared to driving my delta 88 with 150HP and 215ftlbs of torque...
anyway, trade up, build up a 350, or heck, better yet, go for a 383. If you're building it ground up that is.
Please,,, Please,,, don't get me started with those **** hondas those cars are plain annoying not to mention the *******s that drive them please excuse the french.
I have two pontiac 400 's from the mid 70's sitting in my back yard just curious.
Engine: 383 Carb
Transmission: 4L60
Car: 1983 G20 Chevy
Transmission: 4L60
The factory 305 (175 HP/265 TQ, 9.6:1 compression, 4bbl Q-Jet) in the van pulled it around for nearly 200,000 miles.
Car: 1986 Saleen mustang.
Engine: Turbo 5.0.
Transmission: T5.
Axle/Gears: 3.55
What was the top HP rating for a honda in 1984. 90hp
Heck even the bad **** Porsche where under 300 in 1984 and the average mans Porsche was 150hp. Doesnt make the F body twins HP and the mustangs 175-210 look so bad afterall.
Basicly the technology want there in 1984 and the mid 80s HP wars where a dream to anyone that remebers the mid 70s.
kyle
kyle
kyle
kyle
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Just to let everybody know....the HP rating for the L69 was 190, not 180 or 185 as some people said. Ive had LG4's, L69's, LB9's, and L98's. Ill take the L69 over any of them and day. And in stock form, Ive never lost to an L98 with my L69, and Ive come across many. Surprisingly a good engine for its day, and doesnt take a hell of a lot to put one in the 13's N/A...which is decent for a 305.
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
Dual electric fans
Lightweight flywheel with the 5 speed
Aluminum dual plane intake manifold
Car: 4 Mopars total
They actually had a single electric fan. Also, every LG4 ive owned had an aluminum intake manifold. I think the older (pre-thirdgen) LG4's had cast iron manifolds.
Car: 88 Monte Carlo
Axle/Gears: Really Tall ones. Probably 2.73's
Car: 84 Z28
Engine: 305HO
Transmission: Borg Warner T5
Axle/Gears: 3:73
the L69 (305ho) came with 3'' exhaust.my 84 Z28 with cam work cam smoke all the other older 80's car round,never had a mustang do it yet.i even had a good race with a 305hp subaru wrx STI model,good drag it was,he said he was doing 240kph and he couldn't pass me.i think the H.O.'s r wicket
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
