LG4 Knock sensor location
Old Sep 13, 2006 | 11:57 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
Sorry, but one more question. Knock sensor on the LG4s, which side are they on, or does it not matter, just want to make sure the wire from the original wire harness will reach it, thanks again!
Old Sep 13, 2006 | 12:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Do LG4's have knock sensors?
It'll be on the right side of the block if it does.
Old Sep 13, 2006 | 12:55 PM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Right hand side being the drivers side? (i always get the right and left side confused when talking about drivers and passengers)
Old Sep 13, 2006 | 02:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's always the car's right side, or your right side while you're sitting in the driver's seat, so that's the passenger side.
Shouldn't really matter which side it was in, though.
Old Sep 13, 2006 | 03:05 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Passenger side coolant drain hole. Its right above the oil pan, right near the starter.
Old Sep 13, 2006 | 05:48 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Does the LG4 have a knock sensor? I thought it was a carburated car with computer controled distributor? What's the scoop with this?
Old Sep 13, 2006 | 09:40 PM
Damon's Avatar
When the LG-4s compression got raised from 8.5:1 to 9.5:1 in 1985 they started putting knock sensors in them. The L-69 HO motor was always 9.5:1 and always had a knock sensor.
Old Sep 24, 2006 | 10:44 AM
marcika's Avatar
Car: 86 IROC
Axle/Gears: 9 bolt Posi 3.45
I have a 86 IROC with 305 TPI, I just put in a 350 with a T-5, I'm just trying to put it all back together. the 350 block is an older block it has the 2 piece rear mean seal, where would I put the knock sensor? This is my first time doing this. So far I have only worked on my 89 bird with a 2.8
Any suggestions where it would be?
Thomas
Old Sep 24, 2006 | 11:02 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
In the same place. In the coolant drain hole on the right side of the block just above the oil pan.
Old Sep 24, 2006 | 11:13 AM
marcika's Avatar
Car: 86 IROC
ok,
Thanks alot
Chuck84TA
Jul 15, 2016 09:05 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Rustyweb7
Aug 9, 2015 03:05 AM
