heads
Car: 91 rs
Axle/Gears: 4.10
heads
are these heads any good and do yall like the price
eBay Motors: CHEVY 350 CYLINDER HEAD #882-#993 (item 180028008627 end time Sep-22-06 09:45:11 PDT)
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
these are junk stock smog heads. Go to a local junkyard and you'll be tripping over these left right and center. I wouldn't pay money for them, so I didn't even notice the price.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Junk... Sofakingdom actually pays people to TAKE those heads away from him!
Car: 1982 Trans-Am
how much are you planning on spending, and what do you want to get out of the car?
If you want reasonably good factory castings, look for 416, 601, 081 or 083. Do a search on these numbers and you'll find piles of info on them.
Car: 1982 Trans-Am
That's what are on your block right now eh? Well, you know what they're like, you're running them... fast enough for ya? no? So then, you have your answer.
answer this question in more than one sentence, and you'll get some good advice.
Car: 91 rs
Axle/Gears: 4.10
well the motors gone and im just now 16 and dont have my real license yet so when whith my granddady i dont drive to fast and i dont know how much i could come up with if yall could give me some numbers that would help
thanks
thanks
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Since this thread is a new topic, I'll ask the same question. This car is somewhat of a daily driver. I don't drive it on schedule but I drive it fairly often. I was wondering about two styles.
What would be a good set for a street machine to push it to 300-350 RWHP
Also, what would a good set be for total ***** out power, up around 500 RWHP (naturally aspirated) using a 350 engine (of course not the stock one).
Car: 1982 Trans-Am
drew - you've got some growing to do, and some $ to earn. Leave it stock if you're just learning to drive on it, and can't drive it fast due to the elderly in the car... (what the hell is "grandpa" doing in a camaro anyway??)
douchermann - you've kinda got a different question altogether, suited to a new thread. Heads to get 380HP lets say, you'd be looking at vortecs, or aftermarket. Not a lot of factory castings will do that without making it completely unstreetable, and/or having it ported like crazy, and REALLY knowing what you're doing. Some basic 180cc intake port heads in the aftermarket would do it. Canfield, Edelbrock, Trickflow, etc.
500RWHP is a beast. That's like 600-650HP at the crank. In a 350, that's a ***** to the wall racing motor. Like a 220cc intake port set of CNC ported AFR's and a 250/260ish .700"+ lift solid roller cam. Absolutely useless street driven. Again, aside from the few "exceptions" online here, who have a different definition of streetable, and know some tricks to making it "behave".
500RWHP? I'd say use something no smaller than 220cc, then use a turbo/supercharger/nitrous. Thats REALLY close to 700fwhp, which is asking alot from a 350" engine. Thats 2hp/ci.
I have a set of 601 castings on my 350. I had bigger intake valves installed (1.94/1.50 valve sizes... 1.84/1.50 is stock) and screw-in studs and guideplate machinework done as well. I'm quite impressed with these heads. They are a HUGE improvement over the 882/624 heads I had before... I had one of each, lol... the gas mileage stayed about the same, although it needs premium fuel now, since my 350 has flat-top pistons, but the power gain was incredible.
I think Sonix could back be on this, as he built much the same engine that I did, although he used 416 castings.
Car: 1983 G20 Chevy
Transmission: 4L60
I have had the same engine as Air Adam. 355 with ported 601 castings on it. I ran it with a cam that spec'd 204/214 @ .050, .423/.446" lift. I then bumped it to the LT1 roller cam, with the LT1 cam it was probably close to 300 RWHP based on the track times in a 5,300 lbs beast.
Cleaned stock castings with low mileage (guides in great shape)
Various stages of completion
FWIW, I pulled the stock pressed in rocker arm studs out, tapped the holes, and installed the thread in studs and guides in my garage. The port work was done in my garage. I did however send ou the heads to have the valve seats cut for 1.94/1.60" valves. These heads were actually put onto a 305, before the 355, but they ran equally well on both engines.
Lift Intake Exhaust
.050 35.60 15.00
.100 72.40 47.00
.150 105.8 72.50
.200 133.4 98.00
.250 154.1 117.5
.300 180.6 137.0
.350 195.5 145.0
.400 209.3 153.0
.450 217.4 155.0
.500 224.3 157.0
Lift Intake Exhaust
.050 35.60 15.00
.100 72.40 47.00
.150 105.8 72.50
.200 133.4 98.00
.250 154.1 117.5
.300 180.6 137.0
.350 195.5 145.0
.400 209.3 153.0
.450 217.4 155.0
.500 224.3 157.0
Car: 91 rs
Axle/Gears: 4.10
i just want to have a little fun at the strip and just needed some heads to get me out of the 180 hp range and i drove my car for the first time by my self and it was ungodly slow i dont like saying this but ive rode in geos faster than my camaro
Car: 1982 Trans-Am
tune 'er up!
even with heinously bad parts, a 350 in a camaro WILL make you sit up and pay attention. 'specially if you're not accustomed to driving 400HP beasts (like some people are, who will tell you that your combo is slow.. if you're used to a geo, a 350 camaro with CRAPPY parts, WILL be fast).
It needs some tuning done up hardcore. Start there, it's cheaper
Car: 1983 G20 Chevy
Transmission: 4L60
They went a best of 14.7 @ 92 with the 355 in a 5,300 lbs fullsize van. Mid-low 13s or better in a F-body.
With the 305, XE-274 cam, Edelbrock Performer RPM intake, Edelbrock 1406 carb, 1 3/4 x 3.5" headers, and dual 2 1/2" exhaust with X-pipe it went 14.9 @ 95 in the same 5,300 lbs van.
Huh, did you machine the tops of the stud bosses before bolting the guides down, or did you just leave them as cast? I’m guessing you drilled out the pushrod holes also?
If you want a stout 350 that'll beat up on the other cars at school, and you are building it from a naked block (?) then I'd highly suggest a set of 416 or 601 castings. They are 305 heads from the '80s, but they are junkyard GOLD! They are built quite beefy compared to 624/882 heads, and they have a really good chamber design. Nothing compared to modern aftermarket stuff, but its a better design than the old double hump heads, which are still popular today.
If it has the original engine, its got 416 castings. They are basically the same as the 601s, but the 601s have a little bit better chamber design.
Car: 1982 Trans-Am
Why don't you start your own thread? You're not really on topic of the original thread...
416 and 601 heads are very similar to the vintage double hump heads, only with smaller chambers and smaller valves. Install bigger valves, and they are better than the double humps.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
