Nitrous and Crank
Old Sep 30, 2006 | 12:47 AM
Iroc Adio's Avatar
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
Nitrous and Crank
Im thinking about putting a NOS Cheater system in my car. My engine right now has about 490 horsepower. The crank i have is a 383 eagle cast steel crank. It says its rated up to 500 hp. Im looking to put a 150 shot on the motor. Anyone have running a 150 or bigger shot on there motor? Let me know what your setup is and how it goes. Also how you think my motor would hold on a 150 shot. Thanks.
Old Sep 30, 2006 | 11:47 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you have a very high compression ratio already to use nitrous, that's the first thought.
I think you can push that 500HP limit a bit, but not a lot. I would think 100HP is all i'd feel comfortable using in your case.
Old Sep 30, 2006 | 12:08 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
You go over a 100 shot you will be treading on thin ice IMO. by the way is that 490 at the crank or at the wheels? Estimated or dyno?
Old Oct 1, 2006 | 02:19 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
100 hp shot should be ok. Thats what my engine guy told me, and I have a similar setup.
Old Oct 4, 2006 | 10:43 PM
Iroc Adio's Avatar
Car: 1987 IROC
well i have the trickflow kit for 490hp and 440tq at the flywheel.
Old Oct 5, 2006 | 08:24 PM
sixpackmtrspts's Avatar
the last 383 i built using a cast steel scat crank and i beam rods made an estimated 500hp, it has 13:1 comp and dart pro 1 aluminum heads. i have shot a 150 shot on it and is still holding up fine. its in a freinds 70 nova weighs 3000lbs and has a best run of 10.78 on the motor and 10.20 on the unit. we just put the bigger solenoids on it last night, might hit it with 200 shot this weekend, and keep our fingers crossed lol.
Old Oct 5, 2006 | 09:43 PM
Iroc Adio's Avatar
Car: 1987 IROC
thats pretty sick. what did the car run with no nitrous? and let me know how the 200 shot works out
Old Oct 5, 2006 | 10:11 PM
ran a 10.78 at 125, with a 1.42 60 ft. on the unit it runs mid 10.20's at 129mph with a 60ft of 1.38.
Old Oct 6, 2006 | 12:39 AM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Those are nice times! I hope I can get into the 10's soon
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
