Spark Plug Removal
Old Nov 16, 2006 | 01:11 AM
kaos's Avatar
Car: 91Camaro
Axle/Gears: Stock
Spark Plug Removal
Here is a question hopefully someone answers too...lol. I have a 91 Camaro with the 305 TBI and some of the spark plugs are a MAJOR PAIN to simply remove. May sound foolish to some of you but this my first Camaro I have owned so advice is needed. If any tool or technique may help me then I would greatly appreciate the input. If I need to buy more tools then so be it because I am sure I will be tuning up this motor often...lol.
Old Nov 16, 2006 | 07:53 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Some of the back ones are easier to get from underneath the car. I use a 3/8s rachet with 3 inch extension.
Vader's Avatar
You'll need a spark plug socket, a flex-head ratchet to fit it, a 3" extension bar, a 6" extension bar, and an open end wrench to fit the spark plug socket (the flats are on the plug socket for a reason).
Old Nov 16, 2006 | 03:19 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Never understood that gripe. I can get to all of them from the top without too much difficulty at all. Maybe it's that they just haven't had a really tough one yet? :shrug:
Old Nov 17, 2006 | 12:35 AM
kaos's Avatar
Car: 91Camaro
Axle/Gears: Stock
Lost most of my tools moving.....again. lol. Looks like I have to go get some more tools here too finish the job..........Thanks
Old Nov 17, 2006 | 01:21 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
If you got some seriously skinny fore-arms and some nimble fingers, getting them all from the top is not impossible. I've done it once that way, however I prefer to get the rear plugs from the bottom.
I use a ratchet, a 3/8 drive universal joint, 3 inch extension, and of course the socket. With those four tools, I can get them all.
Old Nov 17, 2006 | 02:15 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
easy to do 7 above 8th cyl is tough
3/8 rachet 5/8 spark plug socket with manifolds and air tubes, took me 20 mins
Just reach your arm all the way in, once you get 3 on each side do 4th one by emoving brake booster vacuum hose, and emission tube hose and reach on down.
Now, lift up the car Disconnect the battery( if you touch rachet to starter you get a spark show ) and go from under the y pipe to the 8th plug
Easy really it takes a few times to get used to it. Also i recoomend autolite plat's
Old Nov 18, 2006 | 12:25 AM
MetalliCamaro68's Avatar
Old Nov 18, 2006 | 12:55 AM
kaos's Avatar
Car: 91Camaro
Axle/Gears: Stock
Ok....sounds great, though I do not have the skinny forearms to do all from the top...lol. Just got to get a couple of tools and hope that it all works well for me. I actually use Bosch Platinum. Have had good luck with them so far.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
