Alternator Misaligned, Help
Old Nov 18, 2006 | 05:45 PM
sorch60's Avatar
Here's what seems to be going on. My alternator actually is tilted down in the front so that the belt is not aligned correctly. I have an edelbrock intake manifold but that doesn't appear to be causing a problem. What it looks like is that the alternator bracket needs to be kicked out(toward the front) on the bottom. The crank pulley and water pump look aligned with each other. I do not have a smog pump anymore so here's the question. When I removed the smog pump did I remove a bracket or spacer or something else that would have thrown this off. Or maybe where the bracket attaches to the water pump needs to be spaced. If someone could post a stock v-belt setup picture from an early thirdgen showing specifically the alternator area it would be very helpful.
Old Nov 18, 2006 | 07:31 PM
One of the smog pump brackets belongs behind the alternator spacer, where it bolts to the head.
Either un-hack your smog pump (recommended.... put it back on, and put it together right) or put a washer or something about 3/32" thick behind the alt spacer.
Old Nov 18, 2006 | 07:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
really?
https://webdisk.ucalgary.ca/~jmknopp...0bracketry.jpg
There's supposed to be something on the cylinder head behind the alt on the pivot bolt?
Like, in this picture, i'm missing a washer? https://webdisk.ucalgary.ca/~jmknopp...de%20motor.jpg
Old Nov 18, 2006 | 08:54 PM
Here's the bracket setup on a pre-serpentine L69. Note the thickness of the AIR pump bracket.
Old Nov 18, 2006 | 09:06 PM
Sonix's Avatar
Car: 1982 Trans-Am
that bracket with the "groove" in it doesn't look attached?
Looks like a teeny little washer behind the sleeve?
I've been driving mine with just the sleeve for a few months now... Never noticed any misalignment. Is visually "straight" good enough, or should I throw on a 3/8" washer?
Old Nov 19, 2006 | 08:28 AM
Right... the valve covers on there are too tall, so the AIR diverter valve hits the VC, so the bracket won't go where it belongs, so there's a washer there to keep the whole system aligned.
Visually straight is probably good enough, at least for the belt; but also, not having all the brackets in a bind, to where they'll crack around the holes or otherwise fail from stress, is a good thing.
Old Nov 19, 2006 | 01:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
excellent, more good info from ya sofa. Thanks, i'll look closely at mine some time during it's hibernation.
Old Nov 19, 2006 | 06:10 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Please don't ecourage him!
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
